72 skylark 5.3/th350 help!
Old 07-28-2015, 03:50 PM
The05goat's Avatar
Default 72 skylark 5.3/th350 help!
So I've pulled the old motor and trans bolted new trans and motor went to put in, and my swap mounts don't work, it seems as if the dirty dingo sliders I have max out about 1-1 1/2 inches drone the frame stands, I don't know if I need to change my Buick frame stands to chevy if there different, the cross member of the engine frame has other holes available, also I'm using regular sbc motor mounts attached to the sliders,
Any help would be much appreciated
Jared-
Old 07-28-2015, 06:42 PM
Ablast's Avatar
Frame stands are different. Although all 72 Abody frames are the same each used their own frame stands and motor mounts.
Old 07-28-2015, 06:58 PM
The05goat's Avatar
Can you point me in the right direction of a part # the motor mounts I was using are part #22815
Quick Reply: 72 skylark 5.3/th350 help!
