JEEP YJ 5.3 swap (yj8)
#41
Rannat /ls1.63
Thanks for the real word info, the best info is first hand from guys who have done it . One more week till I'm home hopefully I will get some work done. After. Fix the rest of the fence
#42
Pretty common to find dana, gm, etc gears in a yukon box. Yukon does alot of buying and reboxing stuff into their own boxes, dont worry though dana gears are some of the best out there.
#43
Ok so I got home late Friday night . A bit of jet leg . woke up and hung out with my wife ,went for a walk to debrief the past month, went to good old Costco , picked up some TRI TIP !! for a family dinner.
Oh I even conviced the old lady to stop by the ktm dealer. She's been talking about dirt bike riding .so Im going to try and ease her into it. Bless her hart she think it's going to be easy like riding quads lol. ( she says , I want it to have lots of power and I want to hit jumps.) lol . I Had her sit on a ktm 105 sx .. She was all smiles . More to follow on that later.
Ok some pics I promised before .
Ok so I snaged this of ebay $30<br/>A lot cheaper than AA or novack , plus factory is alway better if you ask me<br/>(Tcase adapter np231 to 4l60e)
An other pic
An other pic
#44
So pic is upside down but here is the part#<br/>Their are several different versions of this all with a bit differnt clocking. This seemed to be the flattest one of the bunch
Ok so the start of the rear bumper trying to keep the KISS method in play<br/>3/16 mild steel hitch / d rings tabs
D ring tags , used my cop saw and then drilled them out . This are weld on front and back of bumper/ they go through
More d ring pics
Bumper
Bumper brackets , I welded plates in the center for strengthening
Pics of inter plates
More pics of the same<br/>BTW I re drilled all the holes to 9/16
The bumper should look for the most part line this , just need to put a 1/8" plate steet across the top to cover everything, oh and weld in the hitch.
This is the D44 I got before my trip with the weak 2.73 gears. Who does that?<br/>OX LOCKER and 4.88 are going in ! Btw does any body have some 5 on 5 1/2 dana 44 front hubs their are interested in selling or trading
#45
I also made some brakets to weld to the frame that mount up to the back of the bumper mounting plate, I'm on the fence or not if I'm going to use them. But that mount plate for the bumper on the back of the frame doesn't really inspire confidence in any real weight .
Shifting gears back to the engine. So while I was gone my brother made and engine stand for the 5.3 . Plan is get it running on the stand with smog equipment and all then do transplant.
Might have to add one more wheel in the center but we will see.
#47
Damn it's been since February that I posted last. The life of a traveling man!
Well a lot has happened I got my wife a dirt bike my self as well. Still trying to keep my house up .
Important things
-Built not bought
-Dana 60 4.88 gears
-Dana 44 OX lock 4.88 gears
-Custom rear bastard pack springs(poor math lift spring didn't lowere me enough
Fronts to follow.
-lowered jeep 3"
-High clearance front fenders. Rears to follow
37/12.5 hummer double beads
Finally pulling the engine today for 5.3 swap. Does anybody know anyone in SoCal looking for a 4.0 / AX15 I will make them a smokin deal. Inject /pcm/harness , I'll give them everything they need .
OK.. So Nxt my bro now has his standalone wiring harness/PCM TUNING up and going , He dies LS/as well as HEMI swap stuff so hit hi. Up
530-356 1173- tell him (crap i saro ) sent ya
Important things
-Built not bought
-Dana 60 4.88 gears
Fronts to follow.
-lowered jeep 3"
#49
Man I suck at posting pics.
Ok now that I have seen some pics
Has anyone used the the style oxlock shifters shown ? And if so did you mount using the top place with 2screws?
#51
Ok I'm at a cross road and need some input.
On my work bench I have a 5 bolt np231c HD/ 6bolt np231j
I have factory adapters for both .
I need vss,
Do I buy JB conversion short SYE for the Chevy np231 with vss, then deal with speedo problems?(getting factory jeep speedo to work from Chevy PCM )/low range
Or do I buy AA 6 bolt to 4 bolt adapter with built In vss, and swap SYE from my existing 231, the price diff up front is $40 this will be the easiest . But I don't like the idea of running two adapters on top of each other.
This is buggin me!!!
I need vss,
#52
I agonized over that one too,I was originally going to try to run the gauges off the Jeep ECU,so bought a TerraFlex SYE with Jeep VSS,Dakota Digital box and built a 231 Chevy/Jeep Hybrid TC.Then I read more and decided to turf the Jeep gauges since success seemed to be hit and miss,with more misses and grief than hits.With the Jeep three wire VSS,I'm going to try a pull up resistor and capacitor trick I saw on here a while back to feed the LS PCM with a sine wave signal,if that doesn't work I'll give the Dakota box a try,should have the Jeep ready for a spin this weekend.
#53
My yj is a 91 so the gauges should be on their own separate from the PCM .
I haven't verified this yet but will today.
I have read the same thing and Dakota digital/ makeing gauges work can be hit or miss,
With that said my jeep has a mech speedo so if I keep my existing SYE and make hybrid case I can keep it and all my gauges . Or do I just go a NP 241 and make is work with JB conversion SYE with vss and deal with gauges later.
Oh and not to forget if I use the AA 6 bolt to 4 bolt adapter I'm kinda stuck with the factory S10 5 bolt clocking. With the np231c with np231j back half. I'm going to crack that thing open today and hope for 6 pinion planetarys
#55
Picture updates to follow
Inline 6 out . A bit dirty
This might be after I pressure washed it and painted the firewall
My 5.3 in the back of my buddy's truck.<br/>I know I should have a truck. And will after this next year , depending on how work goes it with eaither be a old Chevy with 5.3 swap or a old cummins diesel pre 2003
Hard to tell in this pic but after swapping in the fsj Dana 44 my drag link was behind my tie rod , this was bad so I got the MORE 1" steering box relocation bracket. What better time to install . More to follow on that the waggy pitman is a bit to long , I'll have to get something from pick n pull
Here it is after realization looks way better but the pitman is turned in this pic making it look like their is less interference than their will be
#57
Sawza/cut off wheel/air chisel
Tacked in
I like, the looks of this and it was pretty easy.<br/>I have had engines in and out 15 times . Trying to find a good spot. Novak mounts are butter
Had some fitment issues
#58
The corvette manifolds are supposed to clear from what I read.
They definatly do not on my jeep.
Sense this was a major point of research for me I will do my best to document this. I'm going to make it work. I have a plan. I'll let you know if it's worth a damn
#60
I did try the truck Mannies. They fit with a little interference on the driver side.
But as far as running dual cats, I think it would have been much harder with the truck Mannies .
So I made the vett Mannies work
