Camaro Water Pump Spacer for Truck Accessories - Feedback?
Old 09-26-2015, 10:01 PM
sprech's Avatar
Default Camaro Water Pump Spacer for Truck Accessories - Feedback?
Has anyone used the water pump spacers to mount a Camaro water pump to a motor with truck accessories? One of the searches turned up a product from ICT Billet. Considering my water pump is shot, I'd kind of like to switch to the Camaro pump for the way the hose outlet is situated.
ICT Billet Water Pump Spacers
The following users liked this post:
Racer86 (02-26-2021)
Old 09-26-2015, 10:18 PM
1989GTA's Avatar
I have an L92 motor out of an 2007 Escalade(truck). I installed a 2010+ Camaro water pump and the spacing was just fine. Not sure if this is what you are talking about or not.
Old 09-26-2015, 10:22 PM
sprech's Avatar
did you just do a 2010 pump w/o spacers? i was looking at a 98-02 pump that would require the spacers. I'll do a little more research. The motor it would go on is a LQ9.
On Edit: HOLY CRAP, from AutoZone a 2010 camaro pump is $445!
Old 09-27-2015, 11:32 AM
Project GatTagO's Avatar
Received 1,394 Likes on 880 Posts
Amazon.com: ACDelco 251-734 GM Original Equipment Water Pump with Gaskets: Automotive Amazon.com: ACDelco 251-734 GM Original Equipment Water Pump with Gaskets: Automotive
Andrew
sprech (06-28-2020)
Old 09-27-2015, 12:43 PM
jmd
jmd's Avatar
VVT automatic models got similar-to-truck-spacing; that is why his 2010 Camaro pump worked.
Old 09-27-2015, 06:12 PM
67Skylark's Avatar
Here are some pics of 2010 Camaro 6.0 with VVT/Auto trans water pump on a truck engine.
Old 09-27-2015, 06:21 PM
67Skylark's Avatar
Originally Posted by 67Skylark
Attachment 513375
Attachment 513376
Here are some pics of 2010 Camaro 6.2 with VVT/Auto trans water pump on a truck engine.
That is Vet PS/ALT but the bracket is spaced off the head 1.5 inches to line up belts.
Old 09-27-2015, 06:56 PM
dmracing's Avatar
The spacers work. I ran the spacers with a 2000 Camaro water pump and truck balancer. Also ran the Camaro alternator bracket with 3/4 spacers.
Old 09-27-2015, 07:27 PM
1975delta88's Avatar
LS3 or L99 Camaro waterpump has the same spacing as the truck accessories. No need for spacer
Old 09-28-2015, 02:19 PM
bigmandengo's Avatar
Like said, the 2010+ l99 camaro water pump is spaced the same as trucks. I have a brand new pump and tensioner if you're interested. Pm me
Old 09-28-2015, 03:52 PM
-TheBandit-'s Avatar
This is only true for the 2010+ Camaro application. The Corvette LS3 does not have the right spacing for truck accessories.
Old 09-28-2015, 08:42 PM
RicOtt's Avatar
I used Dirty Dingo spacers to put a 2002 camaro waterpump on my LQ9 running truck brackets and harmonic balancer. It has worked like a charm on my 1966 GTO for almost 26,000 miles.
Old 10-03-2015, 04:12 PM
sprech's Avatar
Do you have to change the tensioner with the 2010 pump? For that matter, either of the pumps?
Thanks for the p/n info Andrew.
Old 10-03-2015, 04:15 PM
sprech's Avatar
Attachment 513375
Attachment 513376
I was trying to figure out how you dealt with your steam vent, did you run it to that joint in the upper hose by the bend?
The goal is to try to keep as many off the shelf replacement parts as possible. The spacers have a built in steam vent, otherwise, I figure I have to do something custom.
Also, was there a tensioner change necessary for that pump?
Old 10-03-2015, 04:45 PM
Steven32's Avatar
I'm using this water pump.
I'm also using truck accessories. This is the spacer I got.
Old 10-03-2015, 04:49 PM
Steven32's Avatar
Also got this.
Old 10-03-2015, 04:52 PM
Steven32's Avatar
Old 10-03-2015, 05:24 PM
1989GTA's Avatar
Wrong thread for my reply.
Old 10-03-2015, 06:23 PM
MikeFSKSpeed's Avatar
If you go the 98-02 F-Body Pump Route, We sell a ton of these Dirty Dingo spacers for use with truck spacing:
http://www.ebay.com/itm/Dirty-Dingo-LS-Water-Pump-Spacers-Allows-F-Body-Corvette-Water-Pump-Trucks-/221724938015?vxp=mtr&hash=item339fd60f1f
Old 10-03-2015, 07:30 PM
sprech's Avatar
Thanks for the replies. I am using the dirty dingo alt-ps relocation kit, so I wonder what impact, if any that has on tensioners etc. with respect to either pump really.
After looking at it again, I'm not thinking there is an impact to the tensioner aside from replacing the one for the L99 on the 2010 pump. I'm assuming the idler pulley stays the same and right now, I think I'm using a 78" belt with the DD relocation setup.
Quick Reply: Camaro Water Pump Spacer for Truck Accessories - Feedback?
