Gbody 5.3 swap 4L60e tranny help
I have a 2002 stock 5.3l that I'm putting in my Gbody. For upgrades I'm going with an Holley Mid-Rise intake, 90mm throttle body and 30lbs injectors. My question is what upgrades should I do on my transmission if any at all? My rear end is stick for now but I plan to make it posi w/3:73 gears ratio. This will be a weekend driver.
TransGo reprogramming kit for the 60e, billet servos, .500" boost valve, deeper pan, and a trans cooler will help it to live. Depending on cam specs a higher stall converter will be needed too.
