1970 Bug Mid Engine - Assembly Time (Auto-x videos posted)
Old 12-11-2015, 01:09 PM
70 Bug Mid Engine's Avatar
More assembly done! I had to finish welding the exhaust before I threw it on.
Nice and empty for now
All welding done!
Exhaust is in
Moving on to the engine next. I still need to cut the snout on my blower and weld on a LS1 throttle body flange. After that, the engine should fly together. I only have a few more wires on my harness to pin so firing it up next week is still a possibility.
Old 12-15-2015, 11:49 PM
On to the blower as promised.
Perks of having an in house machine shop...
So I had two choices for the throttle body mounting. I am using a LS1 Camaro throttle body. 1 - run a bolt on adapter and go from 76mm down to 58mm taper. 2 cut the snout and go directly to 76mm. As you see, the snout was cut and I welded a LS1 flange throttle body flange on.
Welded and good to go!
Haven't done any aluminum welding in a while but didn't turn out too bad
Old 12-16-2015, 02:59 AM
Jimbo1367's Avatar
I wish my alum. welding looked that good. LOL
Old 12-18-2015, 06:46 PM
Little more work done! Doesn't look like it will get fired up this week though. Too much Christmas stuff going on.
The floor bracing is finally done. All seat mounts and belt mounts fully welded!
More welding. I need a TIG at my house. The MIG is nice and all but a TIG is more what I am used to.
I also got the blower pulley put on. Stock size is a 3.35". This one is a 2.7". They make smaller but we will see what boost I end up with. I had to clearance the snout how it is so anything smaller will require a lot more work.
Old 12-20-2015, 10:25 AM
Jimbo1367's Avatar
This build has come a long way. Glad to see it in the assembly stage. Do you think you will try starting it before the newyear?
Old 12-20-2015, 03:19 PM
static low 92's Avatar
I can't wait to see this thing drifting sideways and 60 blowing tires off...
Old 12-21-2015, 01:19 AM
Jimbo1367- yes it will be running this year for sure. Hopefully in a few days!
Static low 92 - Sorry to say but there will be no tire smoking videos. This thing is going to hook up! No traction issues for me (we will see)
Old 12-22-2015, 01:06 AM
A little more done.
Sealed. Just needs a texture coat.
[Name:  20151221_224356_zpstygeosb3.jpg
Almost done with the engine harness! It looks like a mess right now
Old 12-22-2015, 09:22 AM
That has got to be the most simple looking engine harness I've ever seen.
Most of time looks like a rats nest lol
Old 12-22-2015, 03:57 PM
Haha ya it is quite simple. Just think of a V8 harness cut in half. The MEFI computer I am using is quite a simple unit. It doesn't need much to make it go! The engine itself really doesn't have many sensors either which helps out.
4 - coils
4 - injectors
1 - crank sensor
1 - TPS
1 - IAC
1 - MAP/Air temp
1 - Coolant temp
1 - Alternator
1 - Oil psi
1 - o2
That is it!
Old 12-24-2015, 12:00 PM
We are getting close to fire up! Only a few more things to go. Hopefully I get some time over the weekend to finish off the last little things.
- Add one more coil wire
- Crimp on TPS and IAC connector
- Add starter
- Add temporary fuel system
- Rig up some power to everything
- Add blower and belt
- Fire!
Old 12-24-2015, 06:23 PM
  #32
I slapped the blower on just to make sure everything lined up. So far it's not looking like the thing will fire off this weekend. Too busy. Guess I'll try for the first of next week.
Old 12-26-2015, 05:56 AM
  #33
dniemi's Avatar
I have been following this build for a while and love it. You have to post a video of that running and driving. Beautiful work.
Old 12-26-2015, 09:31 PM
  #34
Project GatTagO's Avatar
Received 1,394 Likes on 880 Posts
Why the 3 bolt TB flange? Wouldn't a 4 bolt flange and a DBW TB be easier in terms of doing the throttle? Or does the ECU that you are using not support DBW?
Andrew
Old 12-28-2015, 03:37 PM
  #35
Dniemi - You will be getting a video of it running this week! Driving won't be for a little while though.
Andrew - My ECU will support DBW but I do not want to go that route. I like the cable throttle bodies better. I also went with the LS1 flange due to the size. A 90mm/4 bolt would have been way too big. The one I have is 78mm inside and since I cut the snout of the blower, it matches up perfectly. I will post some pictures tonight so you can see what I mean. Also, keep in mind, the stock throttle body was a 58mm so this is quite a step up.
Old 12-29-2015, 12:37 AM
  #36
Andrew - this one is for you. Not much to port match.
Wiring harness 95% done
Old 12-29-2015, 03:47 PM
  #37
I see what you mean! Fair enough. I am just a big fan of DBW and with your engine placement it seemed logical to use DBW, but you clearly have your vision!
Andrew
Old 12-29-2015, 05:52 PM
  #38
Andrew - Don't forget how stubborn I am too! DBC all the way for me! Personally, I think the engine location is more set up for a cable. All I had to do was run it down the middle of the floor, through the rear fire wall, and up and over to mount on the blower. It is like a 6ft long cable with one 90° bend.
Old 12-30-2015, 01:10 AM
  #39
....It is like a 6ft long cable with one 90° bend.
Sounds simple!...LOL....
Andrew
Old 12-31-2015, 02:06 AM
  #40
Well it might not look like much but there is much progress done. For the most part, everything is connected. Firing it off tomorrow might just be possible. I only have the fuel lines left to run.
Quick Reply: 1970 Bug Mid Engine - Assembly Time (Auto-x videos posted)
