5.3 66 elco "cinderella"
Old 01-28-2016, 01:15 PM
kennymox510's Avatar
Default 5.3 66 elco "cinderella"
been on here for a little bit. car is running and driving. little bit about the car
66 elco
2004 5.3
holley single plane
pacesetter longtubes
holley 302-2 oil pan
stock bottom end
proform 750 carb
msd 6ls
efan
tubular lower control arms
hughes performance th350 with full manual valve body
3400 stall
hurst quarter stick shifter.
15 gallon fuel cell
-8an braided fuel line
holley blue fuel pump
aeromotive regulator
weld draglite wheels
calvert 90/10 shocks up front with cut springs
2"drop springs with beltech shocks in the back
future plans are
ford 9"
tubular upper control arms
front disc brakes
cowl hood
custom cam
underdrive pulleys
worked heads.
its just a fun car to drive and **** people off with. its by no means a racecar. still has stock interior with bench seat and all. needs to be painted and some minor body work.
will update as time goes. let me know what you guys think
Old 01-28-2016, 01:18 PM
Old 01-28-2016, 02:04 PM
showdog75's Avatar
Personally I wouldn't paint it,jmo.
Old 01-28-2016, 02:06 PM
I have considered leaving the paint alone and just sanding off the surface rust and having a clear coat put on to protect it.
Quick Reply: 5.3 66 elco "cinderella"
