Installing headers - use anti-sieze?
The GM OEM black oxide bolts have some yellow paste pre-applied. I believe it is anti-sieze.
I used those new bolts from GM.
If not those, I would use anti-seize with dis-similar metals for sure (or high heat applications). Apply about as much as the volume of one pea to the end of each of the bolts.
Doug
Doug
How about the long answer.
Header studs w/ antisieze too??????
I've disassembled to many engines to count and had to many exhaust bolts/studs break off. It's not so hard to remove the broken bolt/stud from an iron head but aluminum is a pain in the *** because it's easier to mess up the threads and then it's even harder to repair. I would certainly use anti seize if it were mine.
8 Second Truck Club
I always use either antisieze or something arp's bolt lube for stuff going into aluminum that does not require locktight. Probably most important when using stainless, as I've had stainless fasteners gall in both aluminum and stainless more than any regular steel bolts.
I always use anti-seize on the header bolts and a small amount on the spark plug threads.
BTW...be sure you are using the proper type of anti-seize. Some are made for heat, some are not.
