Porsche 996 Turbo with LS7
Old 06-17-2016, 07:33 AM
mariusl's Avatar
Default Porsche 996 Turbo with LS7
Bought a 996 Turbo with fire damage a few years ago - luckly not so bad damaged as 1dirtyZs car - as the harness are perfect :-)
Found out I had two choices; Stock 996TT engine, or LSx.
I went with the most fun option:
Ended up buying the kit from Renegade, G96.88 transmission (996 GT2) mounted the LS7.
First test fit:
Wiring - will run the stock LS7 ecu together with the Porsche ECU. The Porsche unit will take care of dash-info.
Little magic box from Motec - relays and fuses programable via USB interface
Stopping power! Endless pads with Performance Friction Discs:
6 pots caliper from 996 GT2. Love new, shiny bits!
Old 06-25-2016, 07:49 PM
hayabusa's Avatar
Man i love your swap makes me want to finish c2 996 swap ls3 sign me up.
Old 06-26-2016, 01:13 AM
BLKMGK's Avatar
Consider a ProEFI, they have code to run the dash gauges over CAN which would allow you to dump the OEM ecu. I'd speak to them about it before buying though just to make sure there would be no issues running the dash and the LS.
Old 06-26-2016, 08:14 AM
mariusl's Avatar
Many ways to drop the Porsche ecu - i may convert to motec dash and ecu later on. May also check out the possibilities of running an arduino to run the dash.
Old 06-26-2016, 08:17 AM
mariusl's Avatar
Current state:
Old 06-26-2016, 09:23 AM
b16gsr's Avatar
following along
Old 06-26-2016, 09:40 AM
Jimbo1367's Avatar
LS1Tech 10 Year
LOL @ the X crossover
Old 06-26-2016, 09:59 AM
mariusl's Avatar
Enlighten me! Know nothing about exhaust, so bought it custom made
Old 06-27-2016, 12:05 AM
BLKMGK's Avatar
Doesn't look too terribly different than a performance exhaust for a Porsche. There's pretty much NO room back there and many exhaust drone like crazy. Off the turbo you get a small catalytic, then bend across for crossover and maybe a muffler, then out the back!
Old 06-27-2016, 07:53 AM
mariusl's Avatar
Indeed, the "x-setup" is very common for the 996 Turbos.
Old 06-27-2016, 05:39 PM
Fierofly's Avatar
Very Nice, You're gonna love it, I've got over 8k Miles on mine. mostly just enjoying the ride, haven't speed tuned yet LOLName:  DSCN3024_zpsqwhidr1w.jpg
Old 06-27-2016, 08:07 PM
BLKMGK's Avatar
Mine has 1/4wave Helmholtz pipes as well, massive difference in drone! That V8 exhaust looks like it will do the job IMO. Nice and compact too.
Old 07-06-2016, 02:38 PM
mariusl's Avatar
The magic Motec PDM - done with wiring and mounting!
Old 07-07-2016, 08:25 PM
AussieDan's Avatar
Awesome build, subscribed!
Old 07-07-2016, 08:30 PM
Red89GTA's Avatar
sweet looking swap! amazing how easy LS seem to slide in there.
Old 07-09-2016, 02:38 PM
faabak's Avatar
Wow, awesome project! Fun too see someone in my country do a LS swap in a Porsche. Btw, du skulle vært på Rudskogen i dag. Following this!
Old 07-09-2016, 02:55 PM
Jimbo1367's Avatar
LS1Tech 10 Year
Originally Posted by faabak
Wow, awesome project! . Btw, du skulle vært på Rudskogen i dag. Following this!
Is that the normal "american bashin" that we here about outside the U.S.? LOL
Old 07-09-2016, 03:45 PM
mariusl's Avatar
Im just 30 minutes from rudskogen, but Gatebil has never been my thing
Old 07-09-2016, 03:46 PM
mariusl's Avatar
No, just told me I should have been at a local race track today
Old 07-09-2016, 03:48 PM
mariusl's Avatar
Breather arrived in the mail!
Installed washer fluid reservoir yesterday - one less error message on the dash 😄
Quick Reply: Porsche 996 Turbo with LS7
