Gas pedal WAY TO SOFT!
Just fired up my nova today after swapping in an LS1. The throttle body spring is VERY WEAK to the point of being undrivable. It's like no spring exist basically. I'm running a lokar pedal and cable assembly to it. Can you purchase stiffer return springs to go on the TB or do I need to add another spring to it?
Cool that's what I'm going to try. Just finding a good place to hook it up at. Another issue I have which doesn't help any is my lokar throttle cable. Where it comes out of the firewall it's right against the head. It's got it pushed over slightly and causing the cable to drag some. Not really anything I can do about that except buy a different pedal. Just spent $150 on this one. Should have went DBW!
