L94 Swap into 07' Denali (L92 ECU)
Old 11-15-2016, 05:55 PM
boomer3's Avatar
Default L94 Swap into 07' Denali (L92 ECU)
Hi Guys, I have an 07 Denali. From what I understand, they had the L92 6.2L with VVT but no DOD from 07-09, and then the L94 came in to replace it with DOD in 2010. The AFM/DOD being the only real difference. Am I right?
My engine is toast, and I have a line on an '09 6.2L and a 2011 6.2. Which I assume are L92 and L94 respectively. Do you think I can get away with running the L94 on my L92 ECU? I expect that it should be fine given that the ECU should have the AFM tune disabled, and so should just run as if it were an L92 (except that fact that it will have 4 AFM lifters that aren't activated ever).
Old 11-19-2016, 04:07 PM
boomer3's Avatar
Any thoughts folks? If this is better suited to one of the other GenIII/IV forums please let me know.
Old 11-20-2016, 12:22 PM
Project GatTagO's Avatar
Received 1,418 Likes on 894 Posts
I agree with what you posted. Personally, I would take the L94 and replace the DOD lifters and install a stock L92 cam. Then it is essentially a L92.
Andrew
Old 11-20-2016, 06:37 PM
vannatta20's Avatar
You need to use your original intake manifold. The older MAP sensor needs to be used in the new engine. Its a different size and calibration. You can use your 07 computer and have the tune modified. I would find a non DOD engine to save on all the hassle.
http://www.hptuners.com/forum/showth...I-did-a-search
Old 11-30-2016, 03:11 PM
boomer3's Avatar
Thanks for the advice guys, much appreciated.
Quick Reply: L94 Swap into 07' Denali (L92 ECU)
