Finishing hybrid conversion and having some electrical issues
Here's the rundown on what I've got for a setup:
2002 Camaro LS6 / 4L60E with factory PCM and harness made into a standalone. I have a CAI, headers, ported TB (stock with cable throttle linkage). I had the PCM flashed many years ago to get rid of the VATS, secondary O2 sensors, etc. I know that I will need to get the car tuned on a chassis dyno by a quality tuner to really get it dialed in, but I did get the car started and running pretty well, at least for a half dozen times I started it, let it run for a little while to get some heat in it and shut if off.
This last time, I'm getting the "Reduced Engine Power" and "Service Engine Soon" message on the bottom of the 2002 C6 Z06 instrument cluster I have wired up and will be integrating into the dash. After doing some reading, I'm assuming that the fact that I switched to the Z06 MAF from the stock Camaro MAF (85mm vs. 75mm) may cause this fault since the MAF tables need to be adjusted? I told the guy who did the original flash this, but this was a decade or so ago, so knowledge about tuning these things have come a long way since then and I'm not sure that he did that.
I had a friend come over and hook up his OBD2 scanner to my car and kept getting a Communication Link error, so it wasn't getting a signal. I got the OBD2 connector pre-wired and I ran the green data wire (same one running the instrument cluster), so it should work. When I looked up a wiring diagram online for the OBD2 port, it was wired the same way (in regards to pin out), but it shows the data wire as purple instead of green. I also have the OBD2 port that I cut out of a 2002 Corvette and it has booth a green wire (in the 14 slot) and the others like the diagram. Can someone tell me why the Corvette connector is wired differently? See below.
Need to figure out why I can't get communication established in order to see what codes are being triggered. Anyone have any ideas? Thanks in advance.
you got it key on engine off right? is the +12v to pin 16 on the obd plug hot when keyed?
Not high dollar, but works fine on his C6 Z06 and his SuperLite with LS7 power.
It could be the issue. I'm looking to get a bluetooth OBD2 adapter and the app for my iPhone.
Im with doug! Maybe even overlay a new wire from pcm to obd2 port, bypass the ic just to see if pcm will communicate
If you have cluster and pcm both from the corvette then im not sure. But as soon as our power comes back on ill look at the vette diagrams.
I did get a bluetooth ODB2 connector and downloaded the Dash Command app on my iPhone. It connected with no issues, but this was with the cluster unplugged, so I have to go back and try it when it's "hot" to see if it was something to due with them both being hooked up or if it was possibly the scanner we used just didn't like it. That first scanner was getting some data, but was slow and timed out, so it may be a case where I have to disconnect the cluster when using the OBD2 port, but I'll figure that out later.
Also of note, the data wire is dark green at the PCM and OBD2 port, but is gray on both the Corvette & Camaro clusters. I assume the data wire goes from the PCM to a BCM and then the cluster since that would explain what controls the ABS, TC and Air Bag lights that I would like to turn off?
With the Dash Command, there were NO codes listed or saved, but under the Pre-Monitoring section, it did have warning for the O2 sensor and O2 heat. I wasn't sure if this is coming up because the secondary 02 sensors were removed (along with VATS) when I got the PCM flashed or not. I wouldn't think this would be enough to trigger the "Reduced Engine Power" situation and would assume anything dramatic enough to kick in the REP would store a hard code, but there were none.
Heres the diagram, it shows them going through a star connector? Which looks like a splice pack to me. Then goes to the DLC on a purple wire to pin 2.
And this is the DLC diagram.
DLC=obd2 port
I believe the problem is corvette ic and camaro pcm, but i really dont know.
Camaro diagrams are basically the same so it should work. Id imagine the pcm isnt telling the ic what the ic is expecting to see. Maybe itll be fine when you plug the ic back up lol
