Outlaw 996 Porsche build
Old 11-21-2016, 06:23 PM
Outlaw 911's Avatar
Default Outlaw 996 Porsche build
Well after 3 years of asking about this car I finally bought it. This car had a IMS failure at 41k miles and was sold. The new owner replaced it and had the engine running again till a missed down shift over rev broke the chain and bent the valves.
Well after another 1.5 years he gave in and sold it to me....
2003 911, Lapis blue, 6 speed
I picked up a 09 LS2 that was removed for a lifter tap....
LS2 new LS3 cam and lifters ready to go
More to come
Old 11-22-2016, 08:40 AM
Outlaw 911's Avatar
Cut the hole in the firewall for better access.
Used my small spot welder to put a flange on the piece I removed for a easy to remove panel.
Here it is re-insalled
Old 11-22-2016, 09:47 AM
4LUX's Avatar
You have to get the rest of the sound deadening/ Insulation off the fire wall. Otherwise the intake will not clear. It is so tight with out it in place. It is a pain in the butt to remove all the glue, lots of thinner and elbow grease!!!!
Old 11-22-2016, 01:21 PM
Outlaw 911's Avatar
I will check it out when I do my next mock up, it it so thin I didnt think it would interfere. A pinstripe eraser works good on the glue.
My Spec stage 1 showed up today so it wont be to long.
Old 11-22-2016, 02:33 PM
hayabusa's Avatar
Great to see another ,I have 99 996 and doing the same.
Old 11-22-2016, 05:00 PM
Outlaw 911's Avatar
Hayabusa,great to here have you got a build thread here?
Old 11-22-2016, 05:23 PM
Outlaw 911's Avatar
Flywheel and adapter from Kennedy
And it was ready for the first mockup
Old 11-22-2016, 09:21 PM
hayabusa's Avatar
Default 996 build
No but I'm getting all the parts together and have started build.
Old 11-24-2016, 07:14 PM
Outlaw 911's Avatar
First mockup fitting, looking good.
Fits up nice, may need to remove the insulation up top.
Will need some extra trimming by the alt to get good clearance.
Old 11-25-2016, 11:50 AM
4LUX's Avatar
See I was not bs's you about having to remove the upper insulation. I also ran after market fuel rails to get clearance. I had to do some extra trimming to get my ac compressor to clear and be able to remove the mounting bolts.
Old 11-25-2016, 11:54 AM
hayabusa's Avatar
Default Insulation
With the aftermarket fuel rails did you still have to remove the insulation?
Old 11-25-2016, 04:08 PM
Outlaw 911's Avatar
4lux ,never doubted you a bit. I think the fuel rail crossover being 1/2" over the intake causes more interferance.
Not much done today but i did get my heater hose adapters made...
Old 11-26-2016, 10:44 AM
4LUX's Avatar
Yes, the the intake is close to 1/2" away from the upper firewall.
Old 11-27-2016, 01:52 PM
Outlaw 911's Avatar
Heres how the heater adapter looks installed.
Old 11-28-2016, 01:50 AM
1dirtyZ's Avatar
subscribing
Old 11-28-2016, 01:10 PM
Outlaw 911's Avatar
Hey dirtyZ, glad to see you here! I have been lurking on your build almost from the start waiting till i could get a car to build.
Old 11-29-2016, 03:35 AM
1dirtyZ's Avatar
its an honor for me to be helping you guys out and give back to a wonderful community that helped me so much!
Old 11-29-2016, 08:15 PM
Outlaw 911's Avatar
DIrtyZ, IIRC your car was the first 996 swap build i had seen. It was the greatest idea ever.
Its taken some time but im on the way with mine.
Old 11-30-2016, 12:54 AM
1dirtyZ's Avatar
funny what happens when someone tells you " you can't do it , its Impossible"
Old 12-02-2016, 06:01 PM
Outlaw 911's Avatar
Got the trans mounts modified ,took a lot longer than I had hoped working on the floor!
Also got the front mounts cut out and drilled enough to hold the engine up witout the jack!! YAY!!!!!
Plenty of clearance for the intake hose and the stock
Latch will still work.
Sorry for the dark cell pic ,Last shot jack down....
Quick Reply: Outlaw 996 Porsche build
