1987 944 Turbo --> LS
Old 01-08-2017, 07:33 PM
Chrenan's Avatar
Made some aluminum brackets and spacers to place the oil cooler. This is the same one I ran on track with the stock engine, it's from an RX-7, fairly big dual pass and has a built in thermostat.
I needed to flip the mounting location so the connections were on the other side to match up with the LS.
Old 01-08-2017, 09:35 PM
Lsxnafox's Avatar
Big motor in little car, nice!!!
Old 01-09-2017, 12:11 PM
408GT's Avatar
My buddy has an 86 turbo 944 that I've been trying to talk into putting an aluminum 5.3 in since he got it. I'll have to show him this thread! Nice work.
Old 01-09-2017, 08:40 PM
Outlaw 911's Avatar
If that turbo is in good shape and running he better leave it alone..turbos are climbing in price fast.
Old 01-10-2017, 11:51 AM
968ls1's Avatar
Default 968 ls2/3
Here is my old 968 i built a few years ago, 402 LS2 W/LS3 head and intake. These cars make great donors for LS swaps.
Attached Thumbnails 1987 944 Turbo --> LS-img_0050.jpg   1987 944 Turbo --> LS-img_0040.jpg   1987 944 Turbo --> LS-img_0037.jpg   1987 944 Turbo --> LS-img_0046.jpg
Old 01-10-2017, 12:34 PM
Chrenan's Avatar
Nice clean install, good motivation for me!
Old 01-10-2017, 01:54 PM
408GT's Avatar
The turbo that was on it was puking oil in the intake, but the guy he bought it from gave him another motor with a fresh turbo. I think the turbo came from Lindsey performance or something like that.
Old 01-13-2017, 06:06 PM
Chrenan's Avatar
Did a test fit with the radiator and custom lower bracket today. Wanted to be sure my oil cooler placement wouldn't interfere. Radiator is a tight fit! Now that I now fitment is OK I pulled the rad back out so I can start scrubbing the engine bay and touch up paint a few scraped areas.
Bracket...
Fits!
Top passenger side corner...
Top passenger side corner looking from the front...
Old 01-22-2017, 05:57 PM
kainedogg's Avatar
Looking forward to the updates bro
Old 01-22-2017, 08:12 PM
Chrenan's Avatar
Well, update is sort of one step forward two steps back. Did some cleanup and paint touchup in the engine bay while it was empty. That went well. Then I went to test fit the custom motor mounts from Texas Performance Concepts and one side has a stud too short to reach through the cross member. So that error will have to be rectified* before I can test fit the engine.
*as an update, Kent at Texas Performance Concepts or me a replacement motor mount VERY quickly, great service!
Old 01-24-2017, 09:57 PM
Chrenan's Avatar
Did a test fit of the clutch master cylinder, it's much larger than the stock one. Looks to just fit, so once I have the hydroboost for the brake master cylinder in hand I can test fit both together to figure out the orientation for the hose connections on the clutch master to avoid interference.
Old 01-25-2017, 07:36 PM
  #32
DW SD's Avatar
Neat project! Will be following along, too.
Old 01-28-2017, 11:01 PM
  #33
Chrenan's Avatar
A little 944 Turbo detail, found a silicone cap to plug the extra port on the coolant expansion tank. The normally aspirated tank only has the one port, but I can save a few dollars by reusing my turbo version for now.
Mounted the starter.
Re-test fit of the clutch master! Some advice from the 944 swap crew that the hydroboost will fit better if the supply for the clutch master is on the far side.
Old 01-28-2017, 11:10 PM
  #34
Chrenan's Avatar
Test mounted the coils where the intercooler used to live. The truck coils won't fit on the valve covers for this swap. This keeps them out of the heat and frees up a lot of space, although I'll have to buy or make custom long plug wires. Was as able to mount this way using existing holes in the car, nothing new was drilled, which is always my preference.
Old 01-30-2017, 09:45 AM
  #35
Chrenan's Avatar
Installed the flywheel. Was going to do the bellhousing too and realized I don't have bellhousing bolts. Old age must be setting in.
Old 02-13-2017, 09:48 AM
  #36
Chrenan's Avatar
Not much to update, had some parts come in so I'm sorting and figuring out some things. Figured I'd install the water pump so I feel like I accomplished something.
Old 02-14-2017, 10:36 PM
  #37
Chrenan's Avatar
Fitted the clutch slave adapter that goes between the torque tube and the engine bell housing:
Old 02-15-2017, 08:59 PM
  #38
Chrenan's Avatar
Did some work on the engine, installed the bellhousing without the clutch, I need to be able to see the pilot bearing to confirm the drive shaft has proper insertion or if it needs adjusting before installing the clutch. Also installed the mounts and cross member and placed it on rollers to be ready to go under the car for install.
Old 02-17-2017, 01:08 PM
  #39
svslow's Avatar
That VDO gauge sender was a good find.
Old 02-18-2017, 09:05 AM
  #40
Chrenan's Avatar
Originally Posted by Chrenan
This little puzzle piece also arrived, M16 Male Metric Straight Thread x M18 Female Metric Straight Thread Adapter. This will let me run the stock 944 oil pressure guage off the opening behind the LS intake on the top rear part of the block.
https://www.mrostop.com/m16m18f87ohg87ms.html
Had a chance to test fit this adapter with the stock oil pressure sender from the 944. Fits well behind the LS1 intake, I just needed to shave the corner of the intake ever so slightly for clearance.
Bottom lip of sender needed some extra space.
Very slight shaving of intake required.
View from directly behind the intake.
Quick Reply: 1987 944 Turbo --> LS
