98 Z28 drivetrain into a 89 Z28
98 Z28 drivetrain into a 88 formula
What do I need to get, and what do I need to do? The 89 is a 5 spd car and my 98 is a 6 spd. Any help here is greatly apreciated. I will be attempting the swap myself here in about a month, thanks in advance.
Chris
Chris
http://www.thirdgen.org/techbb2/foru...?s=&forumid=20
I could type it all out, but here is a good place with quite a bit of info. there is a complete thread just about the LS1 into a third gen then there is a couple of threads about peoples cars specifically. check it out.
Originally Posted by crainholio
The search button is your friend. It doesn't bite.
What about the rear end? I have the rear listed in my sig from my 98 and was wondering if it is interchangeable also. Couldn't find this in the search, along with my question reffering to the throttle cable. What cable is everyone using?
I'm using Lokar's LS1 throttle cable. I don't see why it wouldn't work for a 3rd gen. It comes pretty long and you just have to trim the end at the proper length. I can't help you on the rear end though.
-Matt
-Matt
Same here w/ the Lokar cable. I added a pair of stainless steel fender washers and rubber washers at the firewall junction, just to seal off the engine compartment from the cabin. Also cut the pedal end of the cable off and used an oval-shaped cable end so it would fit into the plastic cup on the 3rd gen pedal.
Originally Posted by Scooter70
Says the guy with the completed third gen conversion.... Chris, If you have questions, direct them at Crainholio.
You only really need Helms manuals for your car and the LS1 donor if you're doing your own wiring harness, in my opinion. I went that route, already had my '82 chassis Helms so I picked up an '01 Helms and fabbed my own "translation" harness between the '01 engine and '82 chassis connectors. Cost was the Helms, a $50 junkyard chassis harness from a '99 or whatever F-body, and $10 worth of junkyard connectors for the '82 side of things.
Other than these three sources, the search buttons here and on thirdgen.org were enough to get me 99% of the way there. One consultation with John @ Speartech regarding hooking up the cyl head coolant vent to my rad, a trip to Mufflex for a custom y-pipe and modified catback, and it was ready for the road.
It's not an easy project, but it's worth the trouble. Here are some shots of it from earlier this month at Pocono north, sneaking up on unsuspecting Z06 and M3 drivers...
http://www.warpten.com/carpics/pocono_oct04/
