Conversion folks please list your conversion in here
Old 10-15-2002, 11:19 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,110 Likes on 728 Posts
Default Re: Conversion folks please list your conversion in here *DELETED*
Post deleted by Pro Stock John
Old 10-15-2002, 11:39 AM
LS1 powered's Avatar
'87 RX7 Turbo II running '00 LS1 and T56....
WrongMotor web site (now w/ videos)
Old 10-15-2002, 04:22 PM
jm134's Avatar
86 Dodge Conquest (Mitsubishi Starion)
99 LS1,T56 stock for now.
Used the Holden front sump oil pan.
The trans tunnel is much larger now.
Plenty of room under the hood after all the turbo support stuff was removed.
The best i can figure is the LS1 is about 70# lighter than the 2.6 turbo 4 banger that was removed.
The T56 weighes about twice the stock five speed.
Should be right at 3000# with the stock leather interior.
Everything is in. All we have left is the exhaust,wiring and plumbing.
The rear end is going changed over the winter.
I am also using:
Howe racing vortec radiator
Dana 44 center section out of a Dodge Viper
97 Vette fuel rail, fuel pump and motor mounts
B&M ripper shifter
Full set of Auto Meter gauges
Lokar throttle cable
Stock wiring Harness
3/4 bore wilwood clutch cylinder
Hope to have pictures posted soon.
Old 10-15-2002, 05:58 PM
Derek 357i's Avatar
1984 BMW 318i swapping in LS1 / T56. In the middle of suspension conversion to handle the extra power, will post pics when available.
Old 10-15-2002, 06:06 PM
Poltergeist's Avatar
John, don't know if you want it or not but I'm doing a slightly built up 95 Impala LT1 and 4L60E into an 82 El Camino. Motor should be going in in the next few weeks.
Old 10-15-2002, 06:41 PM
6.0s10's Avatar
1995 Extended cab S10
1998 6.0 L, using 5.7L camaro ls1 ported heads, forged pistons, rods, custom ground cam. Est RWHP of 440.
99 6 speed tranny
Truck still under construction
Old 10-15-2002, 09:54 PM
Lone Star 1's Avatar
73 Datsun, Gm LS1 craet motor, 4L60E Yank SY3500. Car weights 2600 LB's. You can see it at www.HybridZ.org, members ride section. Ran a 12.13 at 113MPH, 1.74 60'. <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
<small>[ October 29, 2002, 04:18 PM: Message edited by: 240ls1z ]</small>
Old 10-16-2002, 12:39 AM
LSxGuy widda 9sec Mustang
-Joseph-'s Avatar
John you can add mine, although I probably won't be starting on it for a few months. I'm still gathering parts for it.
-1994 Camaro Z28 LT1 Delete
-LS1 5.7L Cast Iron block (5.3L .120 over)
I'm going to have it ~stock to start just to make sure the wiring and fuel systems are ok, then the modding begins <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> Stock LS1 heads, then GMPP CNC LS6. LT1 Cold air induction.
-Quite possibly starting with a built TH350, not sure on converter, probably like a 3500-3600 range. I'll probably install a transbrake, but not use it right away until I get the suspension worked out. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" /> I'll probably look into a T56 conversion after I get tired of the A3 since I can use the A3 in another car too <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old 10-16-2002, 06:00 AM
Sinco's Avatar
1966 Chevy Nova with LS1 crate motor, F.A.S.T. fuel management, 4l60e trans, 12 bolt with 3:73
Old 10-16-2002, 04:01 PM
Speed Demon WS6's Avatar
1998 Camaro V6 5spd
2001 LS1/T56
Conversion in progress..
Old 10-16-2002, 11:41 PM
LMCJ5's Avatar
1979 Jeep CJ5 Golden Eagle
97 LS1/ Clark 5speed
Old 10-17-2002, 12:44 AM
  #32
daddy66joe's Avatar
'66 chevelle w/'99 z28 ls1 4l60e,neil 2500 stall converter w/lockup,b&m floor shifter, hot cam, mac 1 3/4 headers, flowmaster 2 1/4 dual exhaust,
ported m a f sensor, ls6 intake, 4wheel drilled disk brakes, 8.5 rear w/3.90 gears glass front end, aluminum radiator w/16in. electric fan, 6 channel alarm, pop open doors, trunk, and remote starter, 17in. rims w/225/35 front, 275/40 rear. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old 10-17-2002, 03:07 PM
  #33
yagrmiestr's Avatar
In progress......
1967 Camaro RS
2001 LS1 & T56
Pic
More Pics
- Jeremy
Old 10-19-2002, 04:05 PM
  #34
88ls1blazer's Avatar
1988 s-10 blazer 2wd 3.73 open diff w/ 2000 ss ls1/a4 for now, will convert to m6 at later date, after wife gives up and learns how to drive a stick, bone stock for now, just starting on the project, keep an eye out for pics and updates, should have plenty of both,
Andy
Old 10-20-2002, 02:52 AM
  #35
Trace's Avatar
1984 Corvette
Heads and cam LS1
4L60E
ZO6 Wheels and Brakes
pics coming soon
Old 10-20-2002, 04:26 PM
  #36
68LSS1's Avatar
In work installing '98 LS1/T56 in '68 Chevy Stepside 2WD. Also installing Dakota Digital Dash and a/c. Shooting for 400HP n/a.
Old 10-20-2002, 08:06 PM
  #37
driftwood's Avatar
1973 Camaro RS,was original 307,th350 grandma car.
Just began transplant of 2001 ls1/6 speed.Also utilizing LS1 front and rear disc brakes,gauges,cruise,column,wipers,and anything else.
Old 10-21-2002, 12:01 AM
  #38
LS1 IROCZ's Avatar
1987 IROC-Z A4
1998 LS1 M6
my web site
<small>[ October 20, 2002, 12:02 PM: Message edited by: LS1 IROCZ ]</small>
Old 10-21-2002, 12:26 AM
  #39
EARTH MOTORS's Avatar
90 s-10 LT-1 A-4 86 Elcamino LT-1 A-4 85 Elcamino LT-1 A-4 55 Chevy Belair LT-1 A-4 46 Ford coup LT-1 A-350 70 Chevy Truck LT-1 A-4 70 Chevy truck 5.3 A-4 72 Chevy truck 6.0 A-4 Turbo
Old 10-21-2002, 08:11 AM
  #40
RacerX's Avatar
Putting a SBC 350 in a Fiero with a v8 archie kit. In the future, I will be replacing that engine with an ls1/ls6. Using a Getrag 5 spd transaxle and bolting up a cradle off of an 88 Fiero GT.
The following users liked this post:
Ranny (10-06-2023)
Quick Reply: Conversion folks please list your conversion in here
