Oil temp & pressure senders - where to install them?
I am installing aftermarket oil temperature and pressure gauges for my LS1 conversion but I don't know where the best place to tap into the oil source is. I think the original GM oil level sender in the pan and the oil pressure sender on the back of the block must stay installed and connected to keep the factory PCM happy. Is this correct? If I don't need to keep these factory parts it will be much easier.
If so where do you guys suggest I should install my two aftermarket sending units?
Thanks
Thanks
You drill out the oil pressure tree, with about a 1/4" drill bit, and just run a 1/8 pipe tap in there, then thread in your pressure sender. It's already the right OD for the tap. I dont know where you plug in the oil temp. Someone else can help you with that, i'm sure.. You dont have to do anything else. I used a normal tap and wondered why it didnt work. DOH!
olly
olly
I just pulled my factory oil pressure sender, got an adapter....Put my new pressure sender in there. Leaving the OEM pressure connector unplugged. For my temp... I tapped into the part down by the oil pan(which I think 67RS is referring to.)
-Matt
-Matt
On the passenger side, the head has a metric threaded plug towards the rear. I removed that plug and noticed that the threaded hole is the right diameter for a 1/4" NPT so I tapped it. I used a 1/4" NPT plug as a gauge so as not to go too deep.
Above the oil filter, I removed this blank, drill and tapped a 1/8" NPT.
CAUTION!!! National Pipe Threads (NPT) are tapered threads so don't go too deep, otherwise it'll leak on you.
-Matt
-Matt
-Matt
1st one you tapped into is the water jacket. Not oil temp. But I did the same for my water temp sender.
-Matt
-Matt
The lower one is the oil pressure sender, not oil temp.
That's why I provided pics .
V8er, you're correct that the OEM oil sender in the rear is needed to feed info to the PCM. I left that sender along with the OEM water temp in and then drilled, tapped and installed the aftermarket senders shown in the two photos.
The PCM doesn't get a signal of the oil pressure sender. The signal goes straight to the gauge cluster. Just pull the GM oil pressure sender out get an adapter and install your after market sender and it will work just fine.
Last 2 posts are correct from the answers I have been getting from people(including GM, and ecu harness dudes)
-Matt
-Matt
I stand corrected again .
Originally Posted by 68shortstep
what about the coolent sensor? does the pcm like(require) input from that?
-Matt
Keep the stock LS1 coolant temp sensor in the driver's side head and use the passenger side head for an aftermarket gauge. I run dual oil pressure sensors. An electric Autometer gauge from the plate down by the filter and the stock 1970 mechanical gauge reads from the top of the block. As was said before, the PCM doesn't care if you have oil pressure or not.
Regarding the oil sensors, I plan to use the plate above the oil filter for the press. sensor and I am going to tap the temp. sensor into the oil pan, unless anyone sees a problem with this.
Originally Posted by V8er
Does anyone have more info on sensor mounting locations? I will put the oil temp in the pan and probably mount the oil press near the filter housing but the water temp is still a mystery to me. Any ideas?
-Matt
