any wiring harness from a v8 engine 99-2000 will work on ls1?
Old 12-06-2006, 09:47 PM
VideoMaker's Avatar
Default any wiring harness from a v8 engine 99-2000 will work on ls1?
there is a wiring harness on ebay that came from a 2002 camaro ss and the guy listed that it would work with any of these engines:
1999-2000 LS1 5.7L, LS6 5.7L, 4.8L, 5.3L, 6.0L & 8.1L
so i can get a wiring harness off of a 8.1l truck and it should work?
Old 12-10-2006, 02:25 AM
AmericanMuscle313's Avatar
i believe the 8.1L harness is different than the 4.8,5.3,,6.0 harness.
Old 12-10-2006, 08:55 AM
datboibrad's Avatar
i wanted to say i read the truck harnesses are different, especially where they hookup in the cabin.
Old 12-10-2006, 10:12 AM
sawzall wielding director
G-Body's Avatar
The 8.1L harness is different than the 4.8, 5.3, and 6.0 harness. The 4.8, 5.3, and 6.0 use the same harness. The truck and car harnesses are completely different on how they hook up on the car side, but the engine side of the harness is pretty similar. You can interchange the car and truck harnesses when your doing a conversion as long as you change a couple connectors on the engine side.
Old 12-10-2006, 06:34 PM
88s10's Avatar
The connector for the injectors are different from the truck and car. You can use the truck harness and graft the car connector on it. Hope that helps.
Quick Reply: any wiring harness from a v8 engine 99-2000 will work on ls1?
