And the fun begins.......63 Nova LS1/T56
The wheels are from Ace and are called "slick" http://www.acealloywheel.com/ 18X9.5 up front and 18X11 in back
The firewall has to get moved back some 6" and the alternator has to get mounted up higher to clear the UCA's.
Thanks for the kind words.
I spent some time today removing pieces of the firewall and moving the engine back. There isn't much room to run the rear cylinders exhaust pipe but it should be manageable. I have roughly 5" of ground clearance sitting at it's current height in these pics which is about 1/2" higher than what the cross members are.
I finally got the tranny cross member finished. It tucks up about 2" higher than the glide member that was in it.
Here is the rearview, the angle is misleading but the bottom of the new cross member and tranny case is almost perfectly even with the height of the body line. I left the glide cross member in there for a point of reference.
From the side you can see the stock p/g member hanging below the body but the new one is out of sight.
What's the original application (or a part number if you have it) on those bushings?
Originally Posted by slow4dr
I haven't had much time to work on the car lately but I snuck away for a few hours today and made the motor mounts.
$15 in Energy Suspension "link type bushings"
$15 in misc steel
$15 in misc steel
Here is the link, I used part# 9.9488
http://www.energysuspension.com/pages/univ1.html
