Completed E36 LS1 swap total weight and corner weights
And the answer is ----> 3183 lbs with full interior, all fluids, ac and 1/4 tank of gas The car had not settled at all so the corner weights are probably not all that accurate but the total weight sure is. Too bad those BMW motors are so heavy....
Exhaust "tuner style"
It needs some minor tweaking but it is definitely a car again
Originally Posted by Schitzo
might you have taken the weights before the swap? It would be nice to see how the LSX affects the weight distribution
Good idea I will take the car apart and put it back together like it was stock and then take it apart and put it back together the way it is now.
Stock M3's weigh in at right around 3200 lbs.
LS1TECH Sponsor
I laughed, nice job Rob!
Very nice, I think most of the weight is in the tranny though. I am getting ready to put the LS6 in my e30 M3 which had an S50 in it before hand and the LS6 is lighter but the T56 is heavier I believe than the ZF tranny from the M3.
Your vehicle registration probably has the weight listed for plain E36 of your type; otherwise the internet shows E36 M3 at 3219lbs or 3439lbs -- yours appears to be a little lighter ..... go smoke some "stock" M3's E36 with M50 engine 3020lbs
Nice work Rob. Looks to be about 51% front. With you in the car it should be balanced even better.
Andrew
I bought the car without a motor or transmission so I couldn't have weighed the "before" state. Weights for stock M3's are easy to find.
This is probably a newb question, but where did you find a good quality E36 without motor/transmission? That's exactly what I'd be looking for, but the cheapest I usually see is around 4k for one in decent shape. Never tried auto auction/junkyard, was just wondering how you did it.
It is hard for me to believe that any passenger car manual transmission can be much heavier than a T56. A T56 is about 120lb without a shifter, throwout bearing, or bellhousing.
That is what I was trying to say but it didnt come out to well lol
