Anyone using the trans dapt motor mounts on their 67 camaro
I bought the motor mount kit as its suppost to move the motor forward slightly. Problem is either the product is defective or the mount has very poor quality. I had holes in the mount that were suppost to be threaded and were not. Also two of the screws required nuts but the nuts wouldnt fit because it would hit the block. Tried flipping it and it wouldnt work that way. Just wanted to see if anyone else has used these and how the engine sat before I decided to return for a refund or just exchange. Thanks
i'm not running those but why would you want the motor to go forward wouldn't that cause oilpan and header problems I got mine from Carshop they move the motor towards the firewall
