What gas tank to run
I would just run a stock 55 tank and alter it to accept the return line. This way you can run an external pump and corvette filter and add a line to the stock style tank. Thats the route I'm going with my Chevy II.
I had Rock Valley modify their stock tank for the efi set up.
They installed the pump in the tank, quieter and runs cooler,
except when I get low on gas. So far works great. I used the
the return line set up so it circulates the gas. Wasn't cheap
but I needed a new tank anyway. $650.00 I know there
are cheaper ways, and someone on Chevytalk.com was talking
about a F150 Ford tanks that works on a Tri-Five?
Check with http://www.tanksinc.com/. I see they have a 55-57 tank now, maybe they have one set up for their FI Pump. Their pump set up works well with the Corvette filter/regulator.
Pat
Pat
