LT1 to LS1 fuel questions
port, for lt1 using stock return line.
plumb c5 reg. in line with lt1 fuel line, fuel rail fitting for the original,
lt1 feed is the same as ls1,
plumb stock fuel line to ls1 fuel rail,
idk if u that helps.
and the regulator is in the tank on the ls1 on the return line...
it will fit into all the factory looms from front to back clips in ect
youll need to remove your fuel pump assembely and the ls1 regualtor is a simple clip on design inside the tank and it returns fuel into the bucket...you need to put this inside your lt1 tank
I did basically the same thing but mounted it under the car in the stock location. and modified the LS1 fuel lines from my donnor car.
Re'
