LT1 to LS1 fuel questions
Thanks
Cameron
yes the 97 vette fuel rail is like your lt1 as it has a feed, return at the fuel rail and uses the same type of fuel lines.. so yes it would work however! the fuel rail it's self is in the ball park of 200.00 up then you need the fuel regulator which it does not come with. I think thats another 100.00 maybe less. now the real kicker last I checked the 97 fuel rail was on back order. so now you have about 300.00 in a fuel rail that may need replacing if you buy an intake it won't fit. or you can buy the much cheaper fuel filter and be done with it.
fuel rail is gm # 12556705 list is $339.52
fuel regulator is gm # 12554677 list is $87.58
now I would bet your local dealer will sell these for less than list but I still see paying around 300.00 GM parts direct maybe cheaper yet but they do charge alot for shipping which takes all the savings back out..... so again not really worth it IMO
i bought
-6an line 20ft
3 russell Fittings for the 2 ports on the pump assembly and 1 for the fuel rail..
6 -6an hose fittings
1 russell fuel filter
ran the main feed from the tank to a -6an T ran 1 line off the T back the the tank for the FPR, and the other one went to the fuel filter and on to the rail... all in all it was about $175 - $200
Re'
The line that you saw going to the front of your brothers intake was probably the EVAP line. You don`t NEED to use the EVAP line, but that is how the fuel tank vents, if you leave it open to atmosphere the car will run but you may get a gasoline smell since that is usually vented into the intake and burned.
