Identifying a LQ9......hopefully not a LQ4.
Old 10-09-2007, 09:33 PM
stricker76's Avatar
Well, i figured it out. According to a book i bought on the weekend about building LS1's and such, they say that the LQ4 have a throttle cable, whereas the LQ9 is throttle by wire. If thats the case, shes a LQ9. Of course, they also say that a LQ4 is a 6.0L displacing 364ci and the LQ9 is a 6.0L displacing 377ci !??!?!
Old 10-10-2007, 06:59 AM
69LT1Bird's Avatar
The book is wrong. They all are have throttle by wire from 2003 till today. Sorry. If you can find the VIN in the engine I can run it and let you know what is from. I have a 2002 LQ4 that has a cable, 2003 went to throttle by wire in the trucks. PM me the VIN if you have it.
Old 02-06-2008, 07:51 PM
50kta's Avatar
sooooo you can only get the LQ9 out of an escalade?
Old 02-06-2008, 09:12 PM
9540x's Avatar
The LQ9 applications are as follows:
* 2002-2006 Cadillac Escalade
* 2002-2006 Cadillac Escalade EXT
* 2003-2006 Cadillac Escalade ESV
* 2003-2007 Chevrolet Silverado SS
* 2004-2005 Chevrolet Silverado and GMC Sierra Vortec HO Edition
* 2006-2007 Chevrolet Silverado and GMC Sierra VortecMAX Option
Old 02-07-2008, 06:52 AM
forcd ind's Avatar
just to add to the confusion, my 2004 lq4 had a cable, not wire, which doesnt agree with some info-it was out of a 2004 3500 express van
i never searched my block, but if the serial #is on it, the last 8 digits would tell what it is, if you have a nice parts guy
Old 02-07-2008, 02:18 PM
dogger's Avatar
unless it's a pre 01 then you need a spacer because the crank is a little longer.
Old 02-08-2008, 08:46 PM
busta9876's Avatar
the PCM that come with the engine will have the VIN programmed in it...8th digit..will tell you.
V=4.8L LR4
Z=5.3L L59 Flex Fuel
T=5.3L LM7
U=6.0L LQ4
N=6.0L LQ9
G=8.1L L18
Old 02-09-2008, 06:03 PM
locrzn's Avatar
Mine came out of a 2003 express van and its a cable driven throttle. It is an lq4. However, a came change and some reflashing of the computer, your gonna have 400 hp with a set of good headers. With the lq4 and lower compression, you won't have to worry too much about the octane.
Old 03-15-2008, 07:53 PM
i1aroc's Avatar
Originally Posted by Derek @ EDO
take out a plug and look down the hole, flat top= LQ9, dished = LQ4
honestly both engines are great. im running 11's with an LQ4.
May be picking up a 2500HD with an LQ4. Do you think I can get adaquate times by running the stock setup?
Old 03-20-2008, 08:11 PM
TJ
TJ's Avatar
Originally Posted by 69LT1Bird
They both have the same heads. 317.
LQ9, flat top piston 10:1 cr
LQ4 6.7cc dish 9.2:1 cr
They both use .052 head gaskets
thought stock were .060 gaskets?
Old 03-27-2008, 07:41 PM
LSfan70s's Avatar
Hi guys, sorry for insisting on this thread. I got my "LQ9" (or that's what the guy who sold it to me said it was) today, I took a plug out and went with a piece of wire all over the piston and I did not feel anything, I felt it flat, but still have my doubts.
How easy would be to feel the not flat pistons on a LQ4?
Old 03-29-2008, 08:35 PM
  #32
LSfan70s's Avatar
Question
Still feeling it flat... but not sure.
I just took this pics...
I need to leave feedback for this engine on e-bay.
Attached Thumbnails Identifying a LQ9......hopefully not a LQ4.-flat-pist-2.jpg   Identifying a LQ9......hopefully not a LQ4.-flat-pist.jpg
Old 03-29-2008, 09:00 PM
  #33
NemeSS's Avatar
some lq9's came with a 035 head casting
9 out of 10 times a 317 head will be a lq4.
lq4 came with 8cc spherical dish piston and 317 head casting
Old 03-29-2008, 10:02 PM
  #34
stricker76's Avatar
I pulled a head off of mine to verify flattops. Is there not an easier way to tell? vin # on block anywhere? No numbers anywhere to differentiate a lq4 from a lq9?
Old 03-30-2008, 01:51 PM
  #35
LSfan70s's Avatar
Since you already pulled out a head, how easy do you think it is to feel the top of the piston through the plug hole? Can you really figure it out like that?
I think that the one who can answer this easy is someone with a LQ9 and a LQ4 in his/hers hands. But it seems that there's none with that in here.
Old 03-30-2008, 04:42 PM
  #36
LSfan70s's Avatar
Found this usefull link.
http://www.performancetrucks.net/for...ght=lq9&page=2
Old 02-19-2010, 10:51 PM
  #37
i911fire's Avatar
I just found this posting. I have a 2001 GMC Sierra C3. It is factory with a LQ4 and is fly by wire. It was the only a 1 year truck. The next year these became the Sierra Denali. Hope this helps someone.
Old 10-12-2013, 05:21 PM
  #38
Slayer73's Avatar
My vin on my 2004 Chevy Silverado 2500 LS is 1GCGK23UX4F232367
Old 10-12-2013, 09:05 PM
  #39
cobalt964's Avatar
99-02 6.0 were dbc, 03-newer dbw, except 03-04 3500 vans still dbc. I have seen lq4 and lq9's with 317's. only way to differentiate is pistons.
Old 10-13-2013, 07:45 AM
  #40
TJ
TJ's Avatar
my dads 06 van has a cable throttle on it.
Quick Reply: Identifying a LQ9......hopefully not a LQ4.
