do i need???
Old 12-06-2007, 09:40 PM
ACONLP's Avatar
Default do i need???
i got an ls1 motor from a 2001 z28. my question is do i need the filter kit that has the return fuel line. is the 97 vett the only return fuel type.
Old 12-06-2007, 10:18 PM
LS1MCSS's Avatar
You will need a filter and return regulator of some type. You can use the vette filter/regulator setup or use seperate pieces. The vette setup is probably the easiest way to go.
