Dot 4 fluid in brake MC too?
Old 01-24-2008, 03:16 PM
Buckndol's Avatar
Default Dot 4 fluid in brake MC too?
The clutch master cylinder says "Dot 4 only". If I have the brakes drained, is it OK to use Dot 4 in the brakes too? I know you are not supposed to mix.
Old 01-25-2008, 09:12 AM
Buckndol's Avatar
Does anyone have any advise for me?
Old 01-25-2008, 12:47 PM
kosmo38's Avatar
dot 4 is ok. rule is you can go up in dot rating as far as 4,but cant go down. for ex. if you have dot3 fluid you cant used dot2 but can use dot4
Old 01-25-2008, 02:46 PM
Buckndol's Avatar
That makes sense. I am starting with a new master cylinder and new brake cylinders. I would assume that if the system was empty I could change. I have heard you should never mix. I just wanted to hear this from someone that new what they were talking about. Thanks
Any more comments from anyone???
Old 01-25-2008, 04:57 PM
Steve VanS's Avatar
Dot 3/4 synthetic fluid is available at the car parts store. It is compatible with residual DOT3 or 4 fluid in your brake lines/equipment.
