2004 6.0 Denali Engine in 1998 Z28
My brother has an opportunity to get a cheap 6.0 denali engine out of a 2004. Can he use this engine in his 1998 z28? He will be using a t-56 manual, and the 98 pcm, and I'm not sure if the signal from the crank will be the same, and if the t-56 will fit if the crank is longer or different, or what not.
I've heard some rumors that there might be some issues.. Anybody got any advice?
Thanks alot,
Josh
Thanks alot,
Josh
