Help me decide/Cost analysis
Goal 700 RWHP
Target 67 camaro.
Gen 1 way.
Dart block race ready 2000.00
forged rotating components 2500.00
Heads 1800.00
Valve train 700.00
Aftermarktet EFI 3000.00
Supercharger Avg 3500.00
total 13k to 14k
Or
LS2? Pull out ?? here is where I need help....
How much can I expect to pay for the LS2 with harbess ect.
SuperCharger 3500.00
Conversion needs E.g motor mounts ect 1000.00
Any help understanding the LS conversion cosest would be appreciated.
Target 67 camaro.
Gen 1 way.
Heads 1800.00
Valve train 700.00
total 13k to 14k
Or
We have an item by item spreadsheet listed in our thread. It is for an LS1/T56 pullout into a 67 Camaro (search for Swap 67 Camaro). This should give you a good idea about the other stuff you need... I would still go the Gen III/IV route, but it will cost a little...
IMHO start with a clean slate like an LSX block from your favorite performance parts site if you want to go that route. Most of that pull-out will need to be replaced anyways to get to those numbers (Internals, top end, tranny, the list goes on and on).
You can get a forged 408 iron for around $4200 low compression. User 99BLANCOSS sells them here. That's cheaper than your dart block and rotating assembly.
Victor JR EFI intake about $400 with rails
injectors - 72lb something like $400?
speartech harness - $600 or so
miscellaneous sensors - $200
custom ground cam - $400
rockers - $400-$700
pushrods - $120
heads some nice ported 317s with springs- $1500-2500
gaskets, bolts and such - $400
Oil pan - $350-$600. I went with moroso, they have -10an remote mount oil filter lines, good for a turb setup
ATS mounts - $125
SBC urethane mounts - $60
water pump - $120 or so
alternater - $150 or so
ECM - $150 or so
tune for ECM - $300
fuel tank for efi or cell - $350-700
fuel pump - 200-1100 (for aeromotive A100 setup i think it is)
supercharger is around $3500
Hooker ceramic headers - $666 from jegs with gaskets and bolts
Should be able to see 700rwhp. Why not go turbo though? Wouldnt cost all that much more. You wouldnt need the $700 headers, you could use stock 01 truck manifolds bolted on upside down.
What transmission are you going to run? That determines a few other cost factors.
rockers - $400-$700
pushrods - $120
ATS mounts - $125
ECM - $150 or so
tune for ECM - $300
