pinouts for an 01 gmc sanoma 2.2?
the black rectangle box c2. the one you put up for the 2.2 was perfect, but the info i found for the 5.3 was not as complete as what you gave me for the 2.2.
and any chance you have the c100 for the 5.3 too????
plus can you drop the motor in with the maniflods on? we were starting to see how it would fit last night and they dont clear, so i figure we have to put them on after the motor is bolted in?
first, thank you dude. and second we are trying to use the stock manifolds (i think i read they will fit). the c100 is is the same black 16 pin connector. the sanoma has one and the 5.3 has one but the colers of the wires dont match up, so i figured we could just repin it.
hey x to the z, i screwd up. my buddies truck is a 98 sanoma not an 01. i thought he said it was an o1 (long story). do you know if its the same pins for a 98 and an 01. the other stuff matched up for the big rectangle thing so i figure its probably the same i just thought i would ask the almighty x to the z.....
hey x to the z, i screwd up. my buddies truck is a 98 SONOMA not an 01. i thought he said it was an o1 (long story). do you know if its the same pins for a 98 and an 01. the other stuff matched up for the big rectangle thing so i figure its probably the same i just thought i would ask the almighty x to the z.....
Instrument Cluster Diagram
Does anybody have the diagram for the gauges on a 2001 s10? I'm swapping the 5.3 into my xtreme that originally came with a 2.2 and need some help with making the gauges work. i understand i have to recalibrate the tach and all. Thanks. I'll post some pics up of my truck. its not too much but i'm trying to do the most with it.
