5.3 Turbo'd into fox need advice on tranny and harness
Old 07-08-2008, 12:59 PM
Crowder's Avatar
Default 5.3 Turbo'd into fox need advice on tranny and harness
Its going to be a 76mm stock block with a cam. Im needing advice on what cam to buy, what tranny/converter to buy(th350) and where to send my harness. Thanks and here are some options
TRANNY/CONVERTER
http://cgi.ebay.com/ebaymotors/ws/eB...2BSI%26otn%3D4
Or junkyard th350, local shop build with good components and local shop billet converter(650$)
HARNESS
With reworked factory harness
http://www.speartech.com/
http://www.currentperformance.com/eng_mgt.html#Mod
Or has ne1 heard of these guys?
http://cgi.ebay.com/ebaymotors/ws/eB...m=190235035310
Old 07-08-2008, 01:07 PM
70LS1Nova's Avatar
I don't know if I'd get a tranny from ebay. I'm sure lots of people have successfully, but I went with FLT. A proven company with great support. Why not get a 4l80e from a junkyard and go that way? I had current performance do my harness. It's been four years now and have NO complaints. The harness came with six or seven wires to hook up, all wires were labeled and made that part of the installation a breeze. Good luck with the choices you make.
Old 07-08-2008, 01:13 PM
Crowder's Avatar
Im wanting less expensive on the tranny end, and that ebay tranny looks to be a pretty darn good deal as i called them and talked to them. Current was looking like the best option but i might get my buddy to build me a tranny and the converter guys build the converter. This is gonna be more of a 70% Strip/ 30% street car. But thanks for info.
Old 07-08-2008, 02:11 PM
LS1NOVA's Avatar
Cheap way out on the cam is the 02 LS6. $125 in the classifieds here.
Old 07-08-2008, 02:55 PM
mulletnotch's Avatar
I just finished my LS stang project and used a guy on the east coast for my harness. It worked great! I paid under $400 for the harness with relays. I only had to add the fuse panel which was cheap anyway. You can have one added when they build it for cheap also, your choice. Shoot me a PM if interested in contact info. No regrets here.
For the cam I agree - 02 Z06 cam works great for turbo applications and can be had for cheap.
Transmission - I prefer the electronic shifting so I would say 4l60E(the harness will have the trans plug already wired as well). With a little money put into it the 4l60e oughtta last just fine in your mustang since it is light.
Old 07-08-2008, 04:43 PM
Crowder's Avatar
pm'd, im figuring maybe a 560 lift with 220 duration somewhere in that area and replace springs. would i need to change the springs out if i did go 02 z06 cam.
Old 07-08-2008, 08:53 PM
LS1NOVA's Avatar
Yes springs for sure. Im using Comp 918's. Id use Patriot Golds as you will need more spring pressure under boost.
Old 07-09-2008, 11:16 PM
tirefryin_s10's Avatar
Redneck builds good trannys
Current builds KILLER harness'
Zo6 cam works great for boost
Run a good valve spring (918,921,patriot)
Quick Reply: 5.3 Turbo'd into fox need advice on tranny and harness
