Where to order compression fittings?
Old 08-19-2008, 07:18 PM
thunderstruck507's Avatar
Default Where to order compression fittings?
I need some tricky ones...
3/8 compression to 3/8 hose barb
5/16 compression to 5/16 hose barb
I've had no luck at any hardware store or local parts supply place, but I KNOW they exist because I have 1, I just need another one. I have no idea where it came from I just found it in the shop.
Old 08-19-2008, 07:58 PM
jomomma's Avatar
have you tried napa? my local napa is also a new holland tractor service shop too. so try a tractor service shop too.
Old 08-19-2008, 08:29 PM
LS1MCSS's Avatar
You're probably going to have to use two fittings screwed together.
Old 08-19-2008, 09:04 PM
Pop N Wood's Avatar
Try a John Deere dealer or tractor supply.
Worst case you can get a compression to AN and then AN to pretty much anything else at Jegs or Summit.
Why not just flare the hardline and hook the hose directly to that.
Old 08-20-2008, 08:24 AM
downset71's Avatar
try dormann fittings catalog
Old 08-20-2008, 11:29 AM
bczee's Avatar
Your local speed shop or even a good parts start should have a local source for Russell or Aero fittings.. Just ask them if they have a catalog to look at and order from.
If not there is always one of the sponsor, Jeg's or SummitRacing. I know most of the vendors do have web sites to view there catalog.
Question, why would you need a compression to barb fitting?.. I would just flare the end a bit then just and use a fuel Injection grade hose clamp on the hose if your just trying to add a barb end to the hose..?
Old 08-20-2008, 12:06 PM
bada's Avatar
If you have a local Hydraulic hose & gasket shop, they should have it.
Old 08-20-2008, 04:00 PM
Rodder's Avatar
If you go the two NPT fittings route, Home Depot probably has them
Old 08-21-2008, 10:28 AM
S10xGN's Avatar
Parker-Hannfin will have what you want, try here to locate a distributor...
Russ
Quick Reply: Where to order compression fittings?
