350 to 5.3 swap
350 to 5.3 swap
I have a 1974 FJ40 Landcruiser with an early 350 and TH400. I'm thinking about installing a 2001 5.3 in it, wondering if the engine will bolt up to the trans, if mounts are the same, if the torque converter I have will work. The 5.3 has all the wiring and the computer, anything else I should make sure to get at the same time?Thanks for any help.
Should bolt in provide you make adapter for the Gen III 4 bolt hole engine mount to the 350 Gen I three holes.
