LDCM acting up... fix or replace? Cheapest option available?
Driver's side door control module is acting up more often now... used to be once in a blue moon. Is this something expensive that can be fixed by a 3rd party like the ECBM, or is it a non-repairable unit where the fix is replacement?
Is there any mechanism or part of the component that can be cleaned to allow it to lock/unlock the door properly?
Thanks,
Brian
Thanks,
Brian
You think cleaning the main door connection in the accordian will do the trick? I guess it's the cheapest thing to try first! Found a good how-to for replacing the actual relays inside the module on CF if it comes to that.
