Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
oil pressure jumped to 64-66psi while cruising??
Old 12-18-2009, 04:44 PM
SStheBest's Avatar
Default oil pressure jumped to 64-66psi while cruising??
just as the title says...i had just gone to go pick up some food and on the way back on the highway i noticed my oil pressure was steady at 65psi.....it definately was not like this early in the day. Its the stock oil pump. Normally it is around 40-44psi while 6th gear cruising and 60psi at WOT. I dont know if somthin could be clogged in the pump, which i dont know how it would be...i change oil regularly and use the same oil everytime. OR if its the sending unit giving me an off reading...this sucks im supposed to take a 10hr drive tomorrow
Old 12-19-2009, 12:28 AM
WHPLASH's Avatar
You're engine is shot. You're pushing it too hard. You need a rebuild. Too much blow by. You're loosing alot of power. That's a huge sign your engine is on the outs.
Sorry about your BIG problem.
WHPLASH
Old 12-20-2009, 08:14 PM
SStheBest's Avatar
WHPLASH
appreciate the sarcasm ...discovered the sending unit was on its way out the door. It just hadnt completley failed at that time. I was beginning to think the valve in my oil pump may have gotten stuck. Glad its just the unit.
Old 12-31-2009, 01:19 PM
charlie c5's Avatar
Yeah man, your all good. A slightly plugged oil filter or the sending unit going nuts. Both are easy fixes, and none of the above means that your motor is going out..
Old 01-01-2010, 11:08 PM
75TransAm's Avatar
Glad it turned out to just be a sending unit. Your problems could have been much worse.
Old 01-02-2010, 10:25 AM
SStheBest's Avatar
tell me about it
Old 01-04-2010, 03:31 PM
DontRevMe's Avatar
Mine is pegged at 80???? Could it be the sending unit also?
Old 01-04-2010, 03:54 PM
Chicago1's Avatar
Mine is pegged at 129 I going to get the relo kit
http://forums.corvetteforum.com/c5-p...ation-kit.html
