Video of ECS alternator relocation kit on my 2001 z06
here is the video..i figure i should make a new post.... any questions just ask....enjoy
http://www.youtube.com/watch?v=EYX1AREkQ-8
It was $150.00... the install was fairly easy, i had to modify the alt, and the bracket... all in all an easy kit to install
There are many times when you are fabbing up some custom go fast parts that this will help you. Guys that are looking to top mount twin turbo's, opens up a nice place for a vacuum pump, eliminates the need for a long belt if you are supercharged and went to manual steering, or whatever you choose. Be creative!
hashtagBMW
Splice that power wire at the fusable link on behind the passenger head and run it to your alt. Or just run your own power wire from the battery, tape that wire back up around the bell housing. Your mV probably goes down from the wire that your using from the original O-ring connection at the ALT.
Good relo but I dont see the point other then to clear stuff up, losing PS/AC on a C5 sounds rediculous.
Tony.
Tony.
thanks for the tip speed density.....
i did it to clean up the engine bay.... nothing more nothing less.... p/s and a/c i could careless about those accessories...
