Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Gas tank problem.
Old 05-10-2010, 04:53 PM
ssdungeon's Avatar
Default Gas tank problem.
For some reason I can not put gas in my tank full flow I have to barely squeeze the trigger at the pump. Does Anyone know why this is?
Also it only holds half a tank no matter what.
Just give me some ideas on where to look please.
Old 05-10-2010, 05:05 PM
OKcruising's Avatar
Check the crossover jet pump/tubes?
I'm currently in the process of changing my 2004 fuel system to pre-03 style because I was having a myriad of fuel problems, one of which was trickle-in to fill up + and only half capacity.
Old 05-10-2010, 07:14 PM
ssdungeon's Avatar
Default Thanks, I thought it was just my car with the problem.
I found this link what letter is this crossover jet?
Can you give me a ball park of where the jet would be? Ill be under there next week doing the venom mod for this notchy shifter I will pull whatever I need to pull then when I have access to a lift.
Old 05-13-2010, 08:37 AM
OKcruising's Avatar
The crossover jet pump should be a lil non-electrical device(?) that is near one of the two tanks... But I may be speaking out of my rear.
However, to access the crossover tube, it sits up really high, and looks like a dryer hose with a lot of rings.
Over at corvetteforum, I think there are few posts related to how to clean out the jet pump.
What year is your car?
Old 05-13-2010, 09:10 AM
ssdungeon's Avatar
Default thanks
97 im looking over on that forum now.
Quick Reply: Gas tank problem.
