Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
2003 Z06 Oil Pressure
Old 10-26-2010, 06:43 PM
NEED2SPEEDLS1's Avatar
Default 2003 Z06 Oil Pressure
I just had a quick question, and it could be completly normal, but I noticed when my 03 Z06 was idling for about 10 minutes my oil pressure seemed to be a little low, it was around 30 or so (engine was warmed up) My oil pressure is always usually a little under 40 to 50 during normal driving conditions. No motor work done, stock internals, with just intake and exhaust. Just seeing if this is a normal act of the Z06's and that its safe for the pressure to get that low. Any input will be much appriciated! thanks guys!
Old 10-26-2010, 09:10 PM
ChucksZ06's Avatar
If you increase revs to 1500 and pressure climbs and continues to climb as you rev then you are fine. I worry about what my pressure is at 3000 more than at idle. Bearing clearances open up as an engine wears so pressure will drop some with miles.
SCM_Crash's Avatar
My oil pressure in my 03Z is usually around 32-35 when idling after the motor has warmed up to about 180-200*.
While cruising, you should see about 40PSI. Get on the gas and it should shoot up to about 45-60 throughout the RPM range.
Check your oil level while cold and warm. Also, how old is the oil and what oil/weight do you have in there?
I'm running Amsoil Sig Series 0w30 and it's about 60-80* out here most of the time.
Old 10-26-2010, 10:06 PM
pittman's Avatar
My 03 was typically 32-34 with 12,000 miles on the motor at idle
Old 10-27-2010, 02:11 AM
cool thanks for the info, glad its something normal. I run royal purple 10 30 with a K&N filter, usually change it out a little under 3000 miles
Old 10-27-2010, 06:27 AM
pittman's Avatar
I stopped running the RP. I noticed my motors would go thru a quart of oil at the track. I went back to a 5w30 synthetic.
Quick Reply: 2003 Z06 Oil Pressure
