"Service Active Handling"
Anyone ever get this? What all can go wrong with the active handling system?
Also, anyone know where the cigarette lighter fuse is located on the 2001 models? The fuse layout on my 2003 doesn't match my mother-in-law's car (2001 Coupe).
Thanks!
Edit: already scanned for codes - nada. Just get the "Service Active Handling, Service Vehicle Soon" errors. I did notice a vibration when braking, so I believe the front rotors are slightly warped. Could this cause a problem in the active handling?
Thanks!
I found this:
http://forums.corvetteforum.com/show...ing&forum_id=1
I'll start with this and see where it gets me.
More follow-up info in case anyone else encounters this:
https://ls1tech.com/forums/showthrea...32#post2856432
Originally Posted by David Gordon
My car does this real bad. It also has a service activer handling system warming up come on when I am about to make a pass. I wish there was a fuse we could just pull.
The only time I get the Active Handling Warming Up is when I first start it up and try to drive it around a turn too fast (happens to me in the parking garage, usually).
