Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Loud groan from steering when turning right...
Old 09-08-2008, 11:42 AM
pakisho's Avatar
Default Loud groan from steering when turning right...
Blew the belt at the track a few weeks ago, and had to muscle the steering around a little while getting the car on the flatbed/into the garage etc.
Fixed the belt, and now when I really give it the boot in a right turn, I get a very loud groan from the steering. No noise when I go left, though.
Any ideas? Pump? Rack? Kinda odd that its doing it in one direction. Its fine in low speed or low effort turns, but when I crank up the pace its pretty bad.
Fluid is fresh and topped off.
Old 09-08-2008, 09:25 PM
Cole Train's Avatar
hmm. i woulda guessed low fluid but you have it filled. Did you try turning it lock to lock over and over again and make sure there are no air bubbles?
Old 09-08-2008, 10:03 PM
BadMrFrossty's Avatar
I would guess the rack. If it was the pump, it would do it both sides. I think it just might be one side of the rack. Did you have to turn it hard to the right when the belt blew off?
Old 09-09-2008, 01:11 PM
pakisho's Avatar
I was thinking rack as well. Either that or Im a retard and my lugnutz are loose. I had to move the car around a bit, turned it left and right.
With the car stationary, I can spin the wheel as hard as I want in any direction, no problems, but when the suspension is under load, it makes noise.
Old 07-04-2016, 09:58 PM
Danny2tek's Avatar
Bringing this back up. I have the exact same issue. Only when turning the wheel to the right it groans. (in a certain spot of the turning radius once passed it it's quiet)
Was it the rack??
Quick Reply: Loud groan from steering when turning right...
