My tuner figured out my problem!!
My tuner said i was only putting down 320rwhp with my h/c ta something was up...he said my fuel pump was going out at 5000 rpm...hes putting in a new pump this week what kinda gains should i expect and how much should this improve my times??
this is what I ran with the f ed up fuel pump...
7.7 @ 1/8mile 88mph with a 1.63 60ft.
Ls6 Patriot performance heads
Torquer v2 cam
ss4000 yank converter
stock 10 bolt with 3.23
Ls6 Intake
Built Transmission
stage 3 shift kit
full exhaust
Full weight
stock suspension
Torquer v2 cam
Ls6 Intake
Built Transmission
stage 3 shift kit
full exhaust
Full weight
stock suspension
thats what i wanted to hear...i jus need some slicks my mts dr could barely hold last time with the power loss...thanks man this car has been a pain in the ***...what did you do to lighten your car?
My buddy just put a torquer v2 in his 01 ws6, cam only on stock 241's it made 409rwhp and 380ish rwtq through a stalled auto. I would guess ur heads would be good for another 20rwhp so whatevers wrong with your setup is probably leaving over 100rwhp on the table...
My buddy did have to upgrade to 36# injecters before this cam BTW his stockers were about maxed out with his old GM hotcam which is only like 218 intake 228 ex. duration and maybe .570ish lift(?) so I would assume a v2 is maxing em out...
88mph is about right for 320rwhp with full weight. If you could pick up the 70-80 rwhp that you're missing. That should be good for around 95 or more in the 1/8, even with the 60' you had that would be in the 7.2-7.3 range, but as stated above there no reason why you shouldn't be at least a tenth faster in the 60' (maybe spring for a torque arm).
