Friday 5-22-09 results (MIR 1/8 mile Drag Radial "Real Street")
Qual 1...blew tires off at the hit...coast to a 7.0 (1/8)
Qual 2...backed the car down a bit...5.33 @ 140 (1.374 60') qualified #5 of 13
http://home.comcast.net/~tfranklin55...5p33_small.wmv
Rd 1...turned up the heat a bit in the middle...(1.386 60') blew tires off at 100' in the run (lose the round)
http://home.comcast.net/~tfranklin55...spin_small.wmv
Test and Tune pass...same tuneup, a little more suspension travel up front...1.341 60' but spun about 125-150' out (track went away...Stine spun in the same part of the track moments before)
Oh well...we were trying for the 7.x 1/4 mile ET on that last pass...but track wouldn't take it
7 Second Club
I was pretty happy with the results last night. We didn't get ANY data on the first pass but we got the staging technique down. I wish we had added the travel for the first round and been able to adjust the shocks for the last hit which should have been pretty good. Last hit just barley hazed the tires. It was interesting was the car went a 1.38 60' on a soft tuneup and the only thing we did was added the travel and it dropped to a 1.34 and the suspension still didn't look like it was working.
And from the basics we did last night the car has some serious potiential.
I can say i'm really happy,if we would have had a little better track and or another run the 7's were for sure.
run a new best 60ft
run a new best 1/8 mile et
and showed up with a knife at a gun fight and qualified number 5 in a field of 600'' motors with a baby 366.
run a new best 60ft
7 Second Club
run a new best 60ft
run a new best 60ft
car is very heavy...3497 to be exact
Based on my Log data, the last 2 runs, where the car spun, it was going ~7mph faster at 1 1/2 seconds into the run than the 5.33 @ 140 pass
You guys should bring that car down here on june 20th to Peidmontdragway. They are having a 275 drag radial class and there will be some bas *** cars there. That track will hold that car. RPM will most likely be there with their black car and there will be a few turbo mustangs there. They will be running in the 5.30 -.40 range. I think it is free to enter and it pays out like 500.00 to win. I will check and post a link up.
Roxboro Motorsports Grudge Days
same rules for peidmont 275 class275 Shootout General Rules
1. Any type suspension, stock front and rear frame rails
2. Engine combo’s
a. Bid Block short deck conventional heads only
b. No boosted big blocks
c. Single carb or fuel injection
d. No sheet metal intakes
e. Gas or E-85 Ethanol only, no methanol
3. Power Adders
a. One power adder only
b. NOS Big Block 2 stages max
c. NOS Small Block 3 stages max
d. Turbo Small Block single 88 max twin 67 max
e. NOS entries can use one 15lb bottle max
f. NOS controllers and boost controllers allowed
g. Supercharger f1r xi trim or smaller
4. 275/60 drag radial max as printed on sidewall
5. Weights
a. N/A Big Block 2800 Small Block 2400
b. NOS Big Block 3200 Small Block 3000
c. Turbo & SC Small Block 3200
6. No wheelie bars
7. Stock dash and two functioning seats
8. Mufflers required
9. Any production transmission
10. Functioning headlights and tail lights
11. Ladd bars and 4-link add 100lbs
