408 running mid-high 12's????
ok guys well i got my th400 swap done and took her to the track on friday and well im kinda dissappointed... anyways here is whats done to the car
2001 camaro ss
lq4 block .030 over
eagle 4.000 forged crank, callies compstar 6.125 h beams, and mahle -12cc pistons (10.5.1)
"cleaned up" 853's with prc platnium springs
stock LS6 intake and TB
SVO 30lbs
ngk tr6's
TSP mini-stick 235/240 .603/.609 112lsa
slp LT's
clevite h series bearings
th 400 w/ 3000 stall, quarter stick
12 bolt/ 4.10s
sphon torque arm
lakewood lca's
ok guys here is where im confused, recently our track here in spokane wa went from a private owned drag strip to a NHRA sanctioned track. new clocks, concrete lauchpad past the 660' mark and new clocks. now from what ive heard is that the old clocks were 3-5 tenths faster than the new ones we have now but im not completly sure on this. but here is my question with the old clocks the car went a best of 11.98@117 with a 1.78 60' and this last friday the first time out with the th400 and the new clocks this is what she ran
R/T .120 - .187 - .191 - .073 - .037
60' 1.809 - 1.888 - 1.911 - 1.894 - 1.838
1/8 8.149 - 8.166 - 8.325 - 8.232 - 8.145
MPH 85.76 - 86.19 - 84.44 - 85.71 - 85.62
1/4 12.693 - 12.696 - 12.932 - 12.777 - 12.691
MPH 108.59 - 108.78 - 107.15 - 108.66 - 108.70
1st Pass - 2nd pass - 3rd pass- 4th pass - 5th pass
R/T - .108 - .061 - .023
60' - 1.947 - 1.979 - 1.865
1/8 - 8.225 - 8.274 - 8.205
MPH - 86.10 - 86.08 - 85.82
1/4 - 12.748 - 12.802 - 12.744
MPH - 108.99 - 108.97 - 108.67
6th pass - 7th pass - 8th pass
my question to you guys is what do you think would make the car run 7 tenths off of what it ran with the 6 speed and why would it loose 9mph??? a buddy of mine that owns a speed shop here in spokane said he could see it loosing 4-5 mph from the th400 but not 9 mph. the car has been sitting for 2 years with no battery and it now has a hard start issue.(cycle key on/off 3-4 times) then she starts im just wondering if it lost the tune or not??? im sorry this is so long guys but any input on what you think i should look at would be appreciated.
thanks Jason
2001 camaro ss
lq4 block .030 over
SVO 30lbs
ngk tr6's
slp LT's
12 bolt/ 4.10s
sphon torque arm
lakewood lca's
thanks Jason
I would go with a bigger converter too like these guys said. I noticed you mentioned that you have to key the car 3-4 times before it starts, it sounds like an issue with the fuel pump or fuel pressure regulator. Since it has been sitting for two years i would check the car over mechanically before you start making changes. Good luck!
def heads and intake...I read on here the other day about a 408 with i believe the same heads and intake and they changed them out for a fast 92/92 and TFS heads and it picked up 73HP. I'd say something like that and a big stall would run real good together
sorry its been awhile since ive been on here guys i hurt my knee pretty bad lol well anyway its a full street car so that why i went to a 3000 stall and its got a walbro 255 intank and i know it needs heads but on the old clocks and it being a 6 speed it went 12.0@ 117 so im confused on how it lost 9 mph and lost 5-8 tenths. and as for the starting issue after we had jason at texas speed tune it we had no starting issues at all. its like it has a stock tune in it
I good strong 408 should run at least low 11's. Mine runs 11.11 at a race weight of 3700 lbs, and through full exhaust, cats, etc. One thing that stuck out at me is you are running 30# injectors. I've gt 42# SVO injectors. Sure 30# is enough? Also, who is your stall manufacturer? I got almost a full second quciker in the 1/4 simply by changing stalls and going with a Yank. The other stall I had was a POS. You really get what you pay for when buying stalls.
Even with a 3000 stall your trap speed should be alot higher than that. I think you have more than one problem there, but it definitely sounds like torque converter efficiency is one of them. I'd take another look at your injectors as well.
convert is probably way off, I didn't like the 30lbers either.
could be a bad coil pack/ wire etc. as well.
I had a bad coil pack and I lost like 7 tenths and 10 mph.
well guys ive come to the conclusion that the tune is not in it anymore i drove it on the street yesterday and as i got on it, it bounced off the rev limiter at 6300 rpm's??? what is the stock limiter set at?? isnt 62 or 6300??? when my old friend tuned the car for us he set the rev limiter at 7200(never used it) but now its bouncing off at 6300??? i think the guy who tuned it and was storing it for us got mad that i picked the car up and worked on it somewhere else so before i picked the car up i think he reflashed the computer. mechanically the car is fine the only code the ses light is for is because the vss isnt hooked up.
the heads im running are a "cleaned up" 853 so probably flowing somewhere a stock 241 would flow. i know the top end isnt the best by any means but here is another question for you guys, with 400 rwhp what "should" the 1/4 mile times be??? ive been told that 400 rwhp is low 12's which is what the car dynoed with the six speed in it. i dont know guys im thinking the cars tune is gone cause of the hard start issue and because when your driving behind the car going down the road all you can smell is raw fuel.
I am in Spokane and the new clocks are a lot different than last year, some people are reporting .5-.7 tenths slower and 5 mph. I have hptuners and if you want I could look at whats going on. Also remember our track is at 2000' elevation, but yes something is way off.
If you want me to check out the car let me know and we can dink around with it after I get off work. I tuned my head / cam 346 myself and put down almost 420rwhp at Shelley's. I'd like to check your car out (for fun) as its just a hobby of mine.
