11.28 @ 125 Cam only
it was a street nite, so they werent blocking the groove off from the street cars.
anyway heres my best from the nite
60'- 1.699 spinning
330- 4.759
1/8- 7.286
mph- 98.18
1000- 9.472
1/4- 11.289
mph- 125.06
front shocks @ 2
rear shocks @ 8
tire pressure 16psi 26" MT DRs
leaving @ 5k
had i been in the 1.4x where i should be the numbers are there to run
10.8s @ 127/128
-brandon
next time out im trying QTPs and dial the suspension in more
car setup
full drag suspension
245/250 cam
26" DRs
viper spec trans
Spec Twin disk
3230 rw
on a happy note, it did feel good to be racing again after a year and a half
60'- 1.699 spinning
330- 4.759
1/8- 7.286
mph- 98.18
1000- 9.472
1/4- 11.289
mph- 125.06
front shocks @ 2
rear shocks @ 8
leaving @ 5k
10.8s @ 127/128
-brandon
car setup
245/250 cam
26" DRs
viper spec trans
Spec Twin disk
3230 rw
Sick mph and your car is charging hard up to but work on your 2-3 shift and your car will mph better in the 1/8 should go mid 6.x and i see your car going at least high 10.7's
Rob
Rob
thanks rob, i gotta start doing the shifting exercises in the driveway, also my mph was down 2mph on the top end, could be DA related or not having the nose taped off.
once i get the slicks on and cut my 60's to low 1.4s i should "theoreticly" (sp) see 10.60s @ 127/128ish
when you and chris come out here, maybe ill bring money w/ me incase theres an extra spot at the rental
im shooting for next tues if the weathers good
-brandon
-brandon
