new pb 10.24 @ 134 stock ls1
well the other saturday was my last chance to race for this season, i almost didnt go due to very strong winds all day infact for a few hours the track was shut down to only 1/8th mile due to 20 mph head winds , but they ended up letting us run 1/4 mile and even with the strong head wind i ended up setting a new pb, it was 10.24 at 134, the mph was down a few from my best mph due to the wind, the 60ft was a 1.45 here is a video some one recorded from the stands of the pass.
http://vimeo.com/16073595
i was going to swap out the t56 this winter for a auto and go for 9s but when i got home from the races and was parking the oil pressure went to 0 so i am victim of the ls1 oil pump curse, so i am swapping in a ls6 crate motor and staying stick for this next season, i hope to still break into the 9s with the ls6.
stock block,stock crank, rods and pistons and rings, stock heads, stock cam, stock intake,over 100k on the motor before i got it. i did put ls6 valve springs in it and hardened push rods after reading that the stock springs and push rods are crap, i also replaced the rod bolts and head bolts with arp but the bearings and head gaskets are stock. basically the motor still thinks its in a 98 camaro. the trick to it all is 9 pounds of boost here is a pic
