C6 Track numbers
Old 06-29-2006, 12:15 AM
Mr Z51's Avatar
Default C6 Track numbers
My last run of the night was my best.
60'---1.751
1/8--7.778
mph--91.93
1/4---12.01
mph--116.00
My best mph of the night was 116.96
I all I got 10 passes in tonight 5---12.0's,3--12.1's,1---12.24, 1----12.44
The majority of my 60's were 1.7's and low 1.8's
Old 06-29-2006, 07:50 AM
TRYTHSS's Avatar
10 runs!!!! i dont think i have ever run more than 5 in one night!!! keep it going stong
Old 06-29-2006, 09:22 AM
AOC
AOC's Avatar
Nice runs. What tires were you making the passes with?
Old 06-29-2006, 09:43 AM
Mr Z51's Avatar
17'' ET STreets.
http://video.ls1tech.com/video/4d5b0...c40e227a02.htm
Old 06-29-2006, 11:19 AM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
Nice times, I'd think there's more left based on the mph
Derek
Old 06-30-2006, 08:02 AM
bad95killer's Avatar
Derek
Ditto
peace
Old 06-30-2006, 08:34 AM
LS1Tech Co-Founder
Nine Ball's Avatar
Nice results! Be careful with that rearend, they break pretty easily at the track
Old 06-30-2006, 11:31 AM
Checkmate's Avatar
Running et street?? or would it be ok for DR's or stock tires?
Old 07-02-2006, 12:33 AM
9 Sec. Club!!!
dan03mach's Avatar
Any 17" tire is going to shock the rear alot more then a 15 or 16" tire would. I broke a few differentials running 17" ET Streets, since I went with the 15" non at all. The ET streets flex more and give a little bit more cushion then a Drag radial would so it doesn't shock the rear as hard. I would pull back on the clutch a little right before you start to launch the car to give it a little drive train preload, this will help save the rear.. If you just dump the clutch and shock the rear you are looking at breaking it.. I also think you can run a faster ET with the mph and 60fts your pulling.. If you preload the rear like I said you should get some better 60fts and lower ETs.. I hope I can help, I have been doing that for some time now and my 60's have drop alot and the ET's are getting lower..
Dan
Old 07-02-2006, 01:59 AM
Ramshaft's Avatar
Dan
but if you let out on the clutch are you not going to roll throught the light. sorry for the dumb question but i have having a really hard time breaking the 2.xx 60' and i an looking for any help i can get.
oh and those are some good passes, i have run 12 in one night before but that was on 1/8 mile.
Old 07-02-2006, 01:45 PM
9 Sec. Club!!!
dan03mach's Avatar
You don't let out of it, you just pull it back till you get a little preload on the drivetrain.. Then when the yellow lights fall pull back a little more to get the car slightly moving then let out all the way and slam the gas.. It will take some practice to get use to it so you won't red light but once you get it down it will save you on braking parts and help your 60fts.
Old 07-02-2006, 02:46 PM
Ramshaft's Avatar
alright, i will try it thanks
Quick Reply: C6 Track numbers
