First time track results
Well this was my first time at the track and overall im pretty disapointed. Ive only had the car for 3 months and its my first stick(im only 18). Mods and car in sig. 68k miles on the clock, race weight was 3810(190lbs of me plus a system and a heavy toolbox). It was probably 75 degrees or so at San Antonio raceway. Tire pressure was at 27 psi in street tires, and i dint do a burn out, and i didnt powershift.
1st run: 60 ft: 2.5643
1/8 ET: 9.455
1/8 MPH: 81.54
1/4 ET: 14.2096
1/4 MPH: 103.93
Had asr on
2nd run: 60 ft: 2.4109
1/8 ET: 9.2659
1/8 MPH: 81.42
1/4 ET: 14.1689
1/4 MPH: 97.21
Missed 4th
3rd run: 60 ft: 2.5013
1/8 ET: 9.4093
1/8 MPH: 80.73
1/4 ET: 14.2263
1/4 MPH: 102.37
4th run: 60 ft: 2.3287
1/8 ET: 9.1720
1/8 MPH: 81.23
1/4 ET: 13.9515
1/4 MPH: 103.23
I came to the track hoping for a mid 13. I didnt want to launch the car to hard, obviously just look at my 60 ft times, because i didnt want to chance breaking anything. After the first 3 runs i was a little more aggresive on the launch just so i could break in the 13s. Is a 13.95 a good ET for a 2.32 60 ft? I know next time i go i will be even more agressive on the launch, i barely squealed the tires on the last run and not at all on the first 3.
Does everything look right considering my car and its mods? What do yall think? What could i get out of it with a 2.15 60 ft?(which i think i could do next time)
Thanks in advance.
1/8 ET: 9.455
1/8 MPH: 81.54
1/4 ET: 14.2096
1/4 MPH: 103.93
Had asr on
1/8 ET: 9.2659
1/8 MPH: 81.42
1/4 ET: 14.1689
1/4 MPH: 97.21
Missed 4th
1/8 ET: 9.4093
1/8 MPH: 80.73
1/4 ET: 14.2263
1/4 MPH: 102.37
1/8 ET: 9.1720
1/8 MPH: 81.23
1/4 ET: 13.9515
1/4 MPH: 103.23
Thanks in advance.
"The Drag Racing Director"
Originally Posted by 99ssleeper
yes a 13.95 is about right for that 60'...next time take out the sub and toolbox...ride the clutch out and you should be able to get 2.0X on street tires...that will translate to mid/low 13s at 106ish.
there is definately potential there. good luck!
Coach
the car can go to low 13s but you defineetly need to improve your 60'... dude 2.5 ?? my worst was 2.4 and i spun all the way through the 1st and game was over right there! then on my second run, i did 1.93 on stock rubber, on 18'' wheels and ran 13.6 on my stock 06 stang GT. practice more and get some better numbers.. LS1 = god!
Thanks for the replies, once i get over my fears of breaking stuff ill go back and get some better numbers up here
i cut 2.1s but my 1/8th mile sucks for some reason, and the 1-2 shift is pretty damn quick, it just seems my car lacks on the low end compared to most cars here with similar mods. Its sad when i get beat by guys who 60ft could be in the 2.3 range with less mph! doh!
Originally Posted by Shockwave179
I don't know about that...my car ran a 13.5 @ 108 with a 2.327 60 ft
