Drag Racing Tech
Air Bags vs Sway Bar
Old 04-27-2009, 07:09 PM
b.d.d.'s Avatar
Default Air Bags vs Sway Bar
Why is everyone so hell bent on retaining their rear sway bar? There is zero adjustability with a sway bar. With air bags you can adjust from side to side, stiffen it up, loosen it up, etc. So what is there to loose by pulling the rear sway bar off and installing a set of air bags in the springs?
Old 04-27-2009, 07:13 PM
keith_AE2010's Avatar
Set your car up right, and you won't need air bags.
Old 04-27-2009, 07:16 PM
b.d.d.'s Avatar
Or sway bar...works both ways. That is kind of what I am getting at. I see people wanting to drop $500 hogs for a sway bar that looks like it came off a D11 dozer. Why?
Old 04-27-2009, 08:06 PM
tim99ws6's Avatar
Because it's the correct way to set up a drag suspension? I am NOT the kind of guy to typically do this, but you might want to hit the search function on this before insulting the people who have "probably" gone much faster than you with these waste of money drag bars....
Old 04-27-2009, 08:16 PM
NHRAFORMULA00's Avatar
Air bags are just a BAND AID,once you get into the mid to low 11's and adjustabe drag sway bar launches the car straight instead of it torquing over.When it torques over it spins the tires equaling a slower 60 ft.
Old 04-27-2009, 10:12 PM
b.d.d.'s Avatar
Just because I am asking a question you do not have an answer you can back up with facts and data, that does not qualify my question as an insult. As far as going faster than me... For enough money a driver with a learning disability can make an I6 diesel truck run into the single digits, so let's not make "fast" the ultimate badge of honor. A lot can happen in 1320 ft to put a fast car on the road home after the first round. Sorry, I am not like this either, but I tend to give what I get. Thanks for the input.
Old 04-27-2009, 10:58 PM
gator's 99TA's Avatar
sounds like you have your answer and dont want anyone else's input. enjoy racing your S/E car. i will enjoy my BMR anti roll bar.
Old 04-30-2009, 08:48 PM
b.d.d.'s Avatar
No... I love input as long as it is based on facts and data, not just someones opinion based on what they read in a magazine or message board. So, what was gained with the bmr bar? That is what I am trying to understand. What problems did the bar eliminate that nothing else could address?
Old 04-30-2009, 08:54 PM
jmill96Z's Avatar
A bag is a solid fix. One problem is that it adds another variable to the chassis tune which has to be checked/serviced every run. I have a stock rear sway bar with a bag and my car launches straight and has been as low as a 1.31 in the 60'. If I had my choice I would get a drag bar and be done with it, but I make the best with what I have. One time I forgot to put air in the bag, was in the left lane. Shortly after launch, I was in the right lane
Quick Reply: Air Bags vs Sway Bar
