density altitued VS MPH?
just got through a disappointing weekend...
i usually trap over 88mph on the 1/8. i swapped on a ported fast 90mm intake manifold and nick williams throttle body and went for the 1/8. only trapped 85mph...what the heck?
im hoping to hell that my problem is the weather. da was around +1200. before it was around -600. my 60' also went from 1.69 to 1.85 but i kind of expected that with 90% humidity.
so, what are the effects of DA on yalls MPH? 3mph lost with a fast 90 just kills me.
Internet Mechanic
There calculators out there that can help you.
Google for a DA VS MPH.
As for the 60 foot, the weather is not going to make it do that. If the 60 foot and 330 had been the same and the 1/8th to be close but the MPH be way off I could there maybe be a diff due to weather.
Dont get me wrong the lower the DA = Denser, colder, more oxygenated air which will help make more power and hence improve MPH but to lose 3 and if there was no power loss in the motor, Id chalk it up to the 60 foot. now bear in mind, there was no mention of Transmission.
^ move to another state...
Mph to DA can vary...for my car it is more dependent on temp over DA, so every 10-12 degree drop in temp i gain 1 mph...for DA it is anywhere from 800-1000 ft is 1 mph...
also did you get it tuned after the install
