Drag Racing Tech
fastest 12 bolt
Old 05-08-2009, 12:12 AM
T2SLS1's Avatar
Default fastest 12 bolt
How fast has some one gone on a built 12 bolt? reason Im asking before narrowing my rear and going to 35 spline spool.. should i sale it and go m9 moser instead? lsx 4XX mid 9 NA, With spray...
Old 05-08-2009, 07:55 AM
cnorton's Avatar
Here's an example (not necessarily the fastest but a recent one) from the NHRA Winternationals:
AA/SA Brian McClanahan, Alta Loma CA, '02 Pontiac 9.859 10.90 -1.041
That's an LS1 Stock Eliminator car. There are many others.
c
Old 05-08-2009, 08:11 AM
Internet Mechanic
BlackScreaminMachine's Avatar
JL-ws6 still runs on a Moser, went deep 9's on the Eaton HD posi, and as of last yr moved up to a Spool but she is still going strong.
Old 05-08-2009, 06:56 PM
Firehawk441's Avatar
Tektrans runs 9.5's N/A. Paul Z ran 8.3's in a turbo car. N2OStroker is in the 9.3's.
Old 05-08-2009, 07:50 PM
gator's 99TA's Avatar
i am almost positive that stephen fereday went low low 8s in his first black camaro (turbo car) back a few years ago. it was a 12 bolt narrowed. for what you want to do, its a no brainer.
Old 05-08-2009, 07:52 PM
T2SLS1's Avatar
Thanks for the info, so with a narrowed 12 bolt 35 sline axle and spool i should be fine?
Old 05-08-2009, 08:13 PM
SSPerformance's Avatar
east side went 8.2x on a 12 bolt
Old 05-09-2009, 08:57 PM
yrlosing's Avatar
we have run a 12 bolt with 33 and 35 spline in two different camaros, both in the low 8's with 1.3 60 ft on the back tires!
Old 05-21-2009, 09:33 PM
spray's Avatar
8.07@ 169, 1.27 60ft 12 bolt 35 spline Mark williams. Never had a problem with it. Good luck! 3125lbs
