Drag Racing Tech
Battery relocation with dry cell
Old 05-31-2009, 01:13 PM
S_carve's Avatar
Default Battery relocation with dry cell
According to my NHRA rule book when a battery is relocated without a rear firewall you need a battery box. Does this apply with drycell batteries also? Like the Burkhart setup.
Old 05-31-2009, 01:45 PM
Restricted User
Zero4488's Avatar
I'd also like to know this....
Old 05-31-2009, 01:46 PM
droksformula's Avatar
Ya I did the same thing with an optima and the bmr kit. As per rules, if they were actualy doing an inspection they probably would still want a battery box. Even though optima had comercials of trucks running over there batteries, try that with a wet cell and an aluminum batterry box and you will not be driving home with that battery,lol.
Old 05-31-2009, 02:35 PM
ATwelveSec02Z28's Avatar
NHRA does not differentiate between dry, AGM and wet cell batteries. So you must either have a rear bulkhead of either 0.024" thick steel or 0.032" thick alumnium, or enclosed in an sealed box (same thickness as above) or NHRA approved poly box.
Quick Reply: Battery relocation with dry cell
